Go Back   Boat Design Forums > Design > Software > General Computing
Old 07-31-2008, 07:18 PM
Previous Member
Rep: 0 Posts: 0
beginning cad, excellent site
This is an excellent place to start
//www.we-r-here.com/cad/tutorials/level_3/3-1.htm
pasted some of what it covers, but ddi not come out as expected, a great site free
Tutorials
Guestbookhttp:
Links
Videos
Disclaimer
3.1 - ENTERING THE 3RD DIMENSION IS NOT SCARY
LESSON 3-1
INTRODUCTION TO 3-D
LESSON 3-9
ADDING MATERIALS
LESSON 3-2
ISOMETRIC DRAWING
LESSON 3-10
PRIMITIVE SOLIDS
LESSON 3-3
WORKING IN 3 DIMENSIONS
LESSON 3-11
BOOLEAN OPERATIONS
LESSON 3-4
VIEWING 3-D OBJECTS
LESSON 3-12
CHANGING FROM THE WCS TO THE UCS
LESSON 3-5
BASIC WIREFRAME MODELS
LESSON 3-13
MAPPING MATERIALS
LESSON 3-6
LINE THICKNESS
LESSON 3-14
CREATING NEW MATERIALS
LESSON 3-7
REGIONS AND 3-D FACES
LESSON 3-15
EXTRA PROJECTS AND A TUTORIAL
LESSON 3-7a
MORE ABOUT EXTRUDING & LOFTING
LESSON 3-16
PUTTING IT ALL TOGETHER - MODEL A BUILDING
LESSON 3-8
REVOLVED OBJECTS
LESSON 3-17
INTRODUCTION TO RENDERING AND LIGHTING
Topics covered in this Lesson:
Overview of working in 3 dimensions
INTRODUCTION - WHY 3-D?
You may have already found out why CAD has many advantages over manual drafting. One big advantage is that once you've drawn something, you shouldn't have to draw it again. If you manually drew a house plan, you would have to draw a front elevation, side elevations, and possibly a perspective view. With one 3-D CAD model, you can generate views from any angle either inside or outside the house. Afterwards, if your client needs something changed, you can then make the changes once. If you're drawing mechanical parts, you can generate virtual prototypes or even create rapid prototypes. In this manner Boeing was able to design and prototype the 777 jetliner. This level of engineering would be impossible without CAD.
Your company may not do a lot of 3D work, but it is still a good skill to have and it's also more fun than 2D.
You'll be learning the 3-D concepts in the following order:
o
Isometric Drawings (not true 3D)
o
Wire-frame
o
Surfaces / Regions
o
Solid Objects
You will have a chance to draw the same object different ways to see the differences between the various methods.
Before entering the exciting world of 3-D, you'll have to learn some more CAD terminology. This level presumes that you have a good understanding of 2D commands.
3-D CAD TERMINOLOGY
2-D
A concept of displaying real-world objects on a flat surface showing only height and width. This system uses only the X and Y axes.
3-D
A way of displaying real-world object in a more natural way by adding depth to the height and width. This system uses the X Y and Z axes.
Boolean operations
Commands that allow you to add, subtract or intersect solid objects in AutoCAD.
Complex surface
Generally a curved surface. Examples: car fender, landscape contour.
Elevation
The difference between an object being at zero on the Z-axis and the height that it is above zero.
Extrude
The extrude command raises the shape of a 2D outline into a 3D solid. For example, a circle would be extruded into a cylinder.
Face
The simplest true 3-D surface.
Facet
A three or four sided polygon that represents a piece (or section) of a 3-D surface.
Hidden line removal
A way of hiding lines that would not be visible if you were viewing the actual object you have drawn in AutoCAD. (Command: HIDE)
Isometric Drawing
A simple way of achieving a '3-D' appearance using 2-D drawing methods.
Plan View
Also known as the top view, a plan view looks directly down the WCS Z-axis to the X-Y axis.
Primitive
A basic solid building block. Examples would be boxes, cones, cylinders.
Region
A 2-D area consisting of lines, arcs, etc.
Rendering
A complex way of adding photo-realistic qualities to a 3-D model you have created.
Shading
A quick way of adding color to a 3-D object you have drawn. (Command: SHADE)
Solid Model
A 3-D model creating using solid 'building blocks'. This is the most accurate way of representing real-world objects in CAD.
Surface Model
A 3-D model defined by surfaces. The surface consists of polygons. (See facets.)
Thickness
A property of lines and other objects that gives them a 3-D like appearance.
UCS
The user co-ordinate system. This is defined by the person drawing to have easier access to portions of a 3-D model.
View
A particular view of the object you have created.
Viewport
A window into your drawing showing a particular view. You can have several viewports on your screen. Different from the viewports used in plotting.
Wire-frame Model
A 3-D shape that is defined by lines and curves. A skeletal representation. Hidden line removal is not possible with this model.
Z-Axis
The third axis that defines the depth.
As computers and software get more sophisticated, working in 3D becomes more popular. You have more power in desktop machine today, than was dreamed of when CAD first appeared. Be prepared that you will likely need to learn 3D at some point in your career. Once you are comfortable working in 3D, you'll find that you will rarely want to draw in 2D again. Autodesk (the makers of AutoCAD) make other products designed specifically for certain disciplines - Architectural Desktop, Map, 3D Studio Max and more. Depending upon your budget and needs, you may need to look into programs like these. The concepts taught in these lessons will aid you when you work in any 3D program.
Return to the Top of the PageRETURN TO THE TOP OF THE LESSON | RETURN TO THE TABLE OF CONTENTS
CONTINUE TO THE NEXT LESSON - 3-2 >
Take the quiz for this lesson
1960's Glastron beginning overhaul dragonjbynight Boatbuilding 10 04-18-2008 11:56 PM
Excellent deal in CA Baldur Sailboats 10 06-12-2005 09:21 PM
Beginning a big project DONZI22 Fiberglass and Composite Boat Building 1 10-16-2004 10:41 PM
excellent part time job eazyjobs563 Services & Employment 0 10-12-2004 08:17 AM
A big thanks to Uli for posting some excellent images in the Gallery Jeff Open Discussion: All Things Boats & Boating 5 09-24-2002 09:42 PM
