Old 11-06-2007, 04:36 AM
LAD LAD is offline
Rep: 10 Posts: 4
Water Injestion
My current 7.4 L EMI gas engine has suffered from water ingestion due to valve overlap. Has this problem been solved with the newer 8.1 L engines?
Old 11-06-2007, 11:58 AM
mongo75's Avatar
mongo75 mongo75 is offline
Rep: 95 Posts: 262
How does valve overlap cause water ingestion? Valve overlap is normal in all engines for improved cylinder scavenging. I know I didn't answer the question, but if you have water ingestion, you got a problem that needs addressing before you go looking for a new motor.
Danny
Old 11-07-2007, 04:22 AM
LAD LAD is offline
Rep: 10 Posts: 4
Unfortunately,the problem is not just mine. Boat US Magazine ,Jan.,2003 discusses the problem(s )with GM engines that were marinized .
I am looking for info on latest ,8.1L,marine engines and their performance todate.
Old 11-07-2007, 11:07 AM
mongo75's Avatar
Rep: 95 Posts: 262
Gotcha- I was scratching my head trying to figure out how water would get past the risers, which is why I thought you may have had a cracked exhaust manifold or something. Do you know what caused it? I'd like to know for my own knowledge.
Danny
Old 11-09-2007, 09:43 AM
redtech redtech is offline
Rep: 22 Posts: 252
Hey Gunny, scratching my head too, but i'm going to look boat us article and read it before i say much more. i do recall something about exhaust elbows creating a water ingestion problem but have to look back into books to find out why.
as for gm engines in boats very few ever come into the shop for this
Old 11-09-2007, 11:52 AM
LAD LAD is offline
Rep: 10 Posts: 4
Apparently, the design of the elbow and exhaust manifold make a difference at lower rpm's where water and vapor work backup and fall into bottom of manifold ,hence heads and valves. Thats the best this amateur can interpret the work by the pros.
Baffles ,lips ,crossover pipes ,etc. have been used to address the resulting frozen valves,rusted cylinders and bent pushrods.
Old 11-09-2007, 06:58 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
Any marine motor that has a conventional wet exhaust will always be prone to the many problems this system creates. The only answer is a dry exhaust that is jacketed and cooled with water, with the exhaust water injecting to the last few inches of the system to reduce noise.A dry insulated primary exhaust section (headers) plus water jacketing the rear section is good and does away with plastic and rubber exhaust which fail if water cooling stops.
tomkane
Old 11-09-2007, 07:37 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Google reversion.
High performance cams with duration and overlap can cause this.
Marine cams are designed not to do this .
Old 11-09-2007, 08:28 PM
tom kane's Avatar
Rep: 287 Posts: 887
search Hardin Marine Cyclone Headers.It has a lot of info.
tomkane
Old 11-11-2007, 04:34 AM
LAD LAD is offline
Rep: 10 Posts: 4
THANKS- I am restricted to repowering with an 8.1L GM based engine for reasons of space , mounts,etc. This led me to original question. Three marinizers I know of have gone to the 8.1L and have what appear to be different exhaust manifolds and water injection elbows. Have any or all solved the water injestion problem with a raw or fresh water cooled engine?
The 7.4 engine was a nightmare.
S O S ..... we're taking on water ... HighTide Open Discussion: All Things Boats & Boating 24 04-12-2007 11:53 AM
where did the water come from? crispy Sterndrives 0 10-22-2006 04:18 PM
Water Flow Poida Powerboats 3 05-01-2006 09:06 AM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
Fuel, water, black water tank construction kudu Boat Design 12 07-25-2003 06:54 PM
