Old 06-19-2011, 10:53 PM
astull astull is offline
astull
Rep: 10 Posts: 15
water in gas tank
went to use my boat today and to my own stupidity after mixing the oil in i forgot to put the gas cap back on when i backed the boat in i got water in the tank. Before realizing i did this i tried to start the boat what do i need to too to get the water out of the system.the boat is an 87 bayliner with a 85 hp force outboard.
Old 06-20-2011, 07:23 AM
Rep: 1493 Posts: 7,447
You are going to have to empty the tank to start with. If it is a portable tank the job should not be too bad. Also, take the connection off from the end of the fuel line to flush the bad fuel off. The carburetor has a drain screw on the bottom.
Old 06-20-2011, 09:55 PM
astull
Rep: 10 Posts: 15
water in gas tank
thank you for your reply tank is not removeable i believe i got all the gas out of the tank today is there anything i should add to the tank before adding new gas too it
Old 06-21-2011, 08:41 AM
If the gas in your area has ethanol in it, that should absorb any small amounts of water left.
Old 06-21-2011, 12:01 PM
Rep: 3125 Posts: 9,399
Go down to the local auto parts store and get some "dry gas". It's a fuel additive that will clean things up fairly well. Ethanol fuels will eventually too, but Dry Gas gets it done now.
Old 06-21-2011, 10:38 PM
astull
Rep: 10 Posts: 15
water in gas tank
Thanks for all the help this was a good lesson not to do it again what a pain in the but i can see why marine mechanics make good money
aluminum gas tank fishinAK Boat Design 20 01-17-2011 03:05 PM
How Is Water Getting In My Gas Tank? Noob2U Gas Engines 33 08-09-2009 10:40 PM
Converting water tank to Diesel tank steve vilah Boat Design 23 06-25-2007 07:13 AM
water in gas tank chuck mc Open Discussion: All Things Boats & Boating 18 12-07-2005 03:51 PM
gas tank building bushbunny Boatbuilding 12 11-14-2003 10:04 AM
