Old 04-17-2009, 02:53 PM
SSgtjusmc SSgtjusmc is offline
Rep: 10 Posts: 2
volvo4.3GL water in oil
I have a 2000 Fourwinns w/ a Volvo 4.3 GL. I started the boat up 3 days ago and it was running good. I let sit over night in 32 deg. F one night. The next day I put a oil warmer through the dipstick tube to prepare for the 2nd cold night. I noticed the milky substance coming out of the dipstick tube.
I drained the oil twice with no better results.
I checked each sparkplug and no water came out of the cylinders, very clean.
The freeze plugs did not pop out any and there are no visible leaks as the hull was dry.
and when I changed the oil, to circulate the sludge remover, the boat ran fine, maybe a little rough
any Suggestions?
Old 04-20-2009, 07:54 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
milky oil is usually sign of a blown head gasket. A quick compression check will verify. If the compression checks good, start looking for other ways for water to get into the oil.
Old 04-20-2009, 11:58 AM
Rep: 10 Posts: 2
Thanks Ken, I'll start there. That was going to be my next move, but I wanted to get a few opinions on this one.
Old 04-20-2009, 09:07 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
Oil in the water/ or visa versa from head gasket would mean the head gasket had failed from water to oil passages ,--not necessarily blown from the cylinder.
A water cooling system compression check is what you need. Thats a little pump thats fits on the water tank with a guage on it.
Actually it may just be condensation, if the water is seperated, taste it salt, fresh or ethenol glycol.
Could also be inlet manifold joint.
455 water in oil 77taylor Gas Engines 18 05-30-2010 11:14 PM
Water in the Engine and oil krisnowicki Inboards 7 12-03-2007 08:01 PM
water in oil Notayaht Inboards 2 07-27-2006 03:29 PM
Water in Oil Problem ScCoghill Propulsion 3 06-05-2005 02:09 AM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 06:43 PM
