Old 08-04-2008, 01:38 AM
ROBERT PARKER ROBERT PARKER is offline
TATTOO4U
Rep: 10 Posts: 5
Volvo Out Drives Good Or Bad???
I HAVE A 26 FT SLEEK CRAFT I JUST PICKED UP AND I WOULD LIKE TO PUT A 540 BBC I HAVE IN THE BOAT. IT CAME WITH A 350 SBC AND THE 290 VOVLO OUT DRIVE. IVE BEEN TOLD TO HAVE THE SHAFT IN THE LOWER END HEATED (HARDEND) and i should be ok. IT IS THE SINGLE PROP. I WOULD LIKE TO GET THE DULPROP LOWER END BUT AM I WAISTING MY $ ON THIS OUT DRIVE???? ALSO IS IT A BIG DEAL WITH CHANGING FROM SMALL BLOCK TO BIG BLOCK? ONE MORE THANG WHATS UP WITH RUNNING DRY exhaust manifolds. DO I HAVE TO RUN A WET SYSTEM???
Old 10-14-2008, 11:49 AM
2850 Bounty 2850 Bounty is offline
Rep: 10 Posts: 15
First.... you'll be pleasantly surprised at the performance with the Duo Prop. Many times it will perform as though you added 100 HP with no other changes.
Maybe consider staying with a good strong and much lighter weight SBC (383 for example) and installing the Duo Prop lower unit.
Some critical shimming is required, but the AQ series DP will bolt on to your existing Intermediate housing.
The Flywheel Cover is same for BB or SB.
You do need the 153 tooth flywheel though.
No... you do not necessarily need to stay with a Thru the Drive exhaust (if I understand your question) .... it will, however, need to remain a WET system in that hull unless you do not enclose the engine..... and I doubt if you want that.
You cannot beat this drive for reliability and strength and ease of service.
Install NEW Primary Drive Shaft bearings! Period!
Old 10-20-2008, 03:43 PM
jflongwell jflongwell is offline
Rep: 10 Posts: 9
I have a 350 w/DP and it gets good fuel economy. One problem with the DP is cavitation erosion on the small prop means repairing (welding) it about every three years or so.
Old 10-21-2008, 10:24 AM
Rep: 10 Posts: 15
I know exactly what you are talking about re cavitation burn/erosion.
I am running twin 270 HP 5.7Ls with the 290 DP's, B-5's.
You just live with it, keep them protected with an epoxy paint, or go to the SS props, of which I'm not willing to do quite yet.
Shaft damage X's 2 would be expensive. I do have impact coverage, but would prefer to not use it.
Old 10-21-2008, 10:56 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 603
I think it's against some unwritten rule to use "fuel economy" in sentences discussing boats!
As per cavitation erosion, I'm getting it on the leading edges of the large prop. '87 AQ271A with the AQ290DP running B4's. There's no erosion on the small prop which I got with the B5's. Strange. One piece of advice on the DP's, don't defer maintenance. If it says replace bellows every two yrs (or whatever) do it! I didn't, paid the mechanic later ($$$). Other than that, bulletproof drives IMHO.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 10-21-2008, 01:22 PM
Rep: 10 Posts: 15
Speaking of advice, for those of us who work on these drives have no doubt at one time or another removed a corroded-in-place propeller from a Duo Prop shaft.
It almost always involved cutting an otherwise good propeller from the shaft. $$$$$. It's too bad to see this.
So, Lake, River or Salt use..... pull your props routinely (at least once per season) and clean and grease your splines!
Volvo Out Drives Go Or Bad? ROBERT PARKER Metal Boat Building 0 08-04-2008 01:00 AM
Luanan Plywood-good or bad? holly Multihulls 7 08-19-2007 10:39 PM
Hunter Sailboats - Good or Bad Opinions? Tres Cool Sailboats 0 07-01-2007 04:06 PM
Ship constructor good and bad points stephen gibson Software 3 05-08-2007 04:50 AM
Fisher10 conversion or luan good and bad! lewisboats Wooden Boat Building and Restoration 4 06-07-2006 01:51 PM
