| Volvo Oil Pressure problem just started my volvo 260B engine. don't remember what the oil pressure should be but i'm getting 20lb. when i rev the engine it jumps between 20 and 60 back and forth. anybody with an idea would be helpfull..thanks |
| sounds electronic, from sensor, do you know how to measure the resistance over it? or maybe just get another sensor, OR plug in an old style press gauge robbed from old car, and check it out |
| no i don't know how to measure the resistance. if you tell me how i would try. would you know the location of the sensor? you don't think it's the oil pump. |
| you will see a thing with two wires or sometimes one, screwed into the block, small thread 1/8 bsp or ntp with is about 3/8 inch in thread diametre You would need multimeter and the values from a volvo shop manual or dealer, these things are as cheap as chips, just get a new sensor from any auto supply chain, make sure correct voltage, your car will have same too oh and if you google up (measuring oil sender/ senser, resistance) you will have a nights light reading |
| Milky outdrive oil Volvo-Penta | jflongwell | Sterndrives | 5 | 12-19-2007 09:16 AM |
| Gas in crankcase oil problem | jflongwell | Gas Engines | 5 | 10-03-2007 06:45 AM |
| Which oil for Volvo/ Penta 5.0L? | ucf_motorcycle | Sterndrives | 4 | 06-14-2007 12:17 PM |
| Diesel Oil Pressure Query | darrenyorston | Diesel Engines | 3 | 11-25-2006 07:39 PM |
| Water in Oil Problem | ScCoghill | Propulsion | 3 | 06-05-2005 01:09 AM |
