| Volvo 5.7 GS flywheel I have a 24' Larson with a Volvo 5.7 GS engine. I suspect that the wrong flywheel was installed on a repair job. I think the next step is to count the number of teeth on the current fly wheel. Can you tell me what the correct count would be? Also, I have heard that this is a GMC Tahoe engine. Can I use this engine flywheel? Thanks for any help you may provide. |
| Could be wrong flywheel teeth count or wrong starter teeth count or wrong starter. Get a good mechnic to tell you whats now wrong. Do not use the same mechanic again. He does not know what he is doing. |
| If it came out of a Tahoe it won't work on a boat. Make sure the electrics and fuel systems are marine so you don't blow yourself up. You can make it safe, but the boat will perform like a pig. Those engines are set for a completely different use.
__________________ Gonzo |
| volvo marine vs ford 351 windsor | kennyharding | DIY Marinizing | 8 | 05-28-2005 01:21 PM |
| Volvo Open 70 Design | woody_paul | Boat Design | 0 | 12-08-2004 03:07 PM |
| Volvo Composite Stern Drive | Jeff | Powerboats | 5 | 08-31-2003 04:48 PM |
