| Varnish in Gas Tank I have a 130gal tank(metal) that I've pumped down to about a 1.5" of fuel/muck/varnish in the bottom. If I dump a few gallons of acetone and let it sit for a couple days, then use a pressure washer to break it up. Can I pressurize the tank with an air compressor to push the remaining, broken up, sludge out? What does everyone think of this idea? |
| The pressure won't get the sludge out, you need a pump. The pickup on the tank does not reach the bottom of the tank.
__________________ Gonzo |
| Get a positive displacement pump. connect a pipe to a stick and suck it all out like cleaning with a vacuum cleaner. |
| I like Frosty's idea, but a pump that survives acetone may be hard to find. As an alternative you could pour in a bottle of detergent followed by lots of water, then stir and pump out the emulsion/suspension.
| Well he has'nt put the acetone in yet. if you did swill it with water and soap you could use a wet vac |
| Don't use a shop vac. You will have an explosive inferno.
| So, dump some laundry detergent in the tank, stir it up, pump it out? |
| We deal with this daily, I strongly recommend you find a local tank cleaning company. Don't let a guy with a couple of racor type filters show up, connect to your fuel line and tell you this is the way it is done! |
Its deisel,-- ive welded diesel tanks with diesel still in it. If you want to be safe then run the vac for 5 minutes evacuating the air/ fumes first. Or run an engine (generator etc) near by and put the fumes in the tank. This is what you do to make petrol tanks safe before cutting in half with a grinder. |
| http://en.wikipedia.org/wiki/List_of...o_Die_episodes episode 180 Suck & Blown (a.k.a. Suck and Blow) August 24, 2007 Atlantic City, New Jersey Two men attempting to siphon gas from a car, pull out an industrial vacuum to ease their workload. When the electric fan in the vacuum creates a spark, the gas ignites, causing the vacuum to explode, killing the men instantly.
| One minute gas --one minute diesel. Two different fuels Hoyt |
| So you've been lucky so far, and haven't blown yourself up with diesel fumes yet? Doesn't prove it can't happen.... Here's an MSDS (material safety data sheet) for diesel. http://www.hess.com/ehs/msds/9909DieselFuelAllTypes.pdf If you read it, you'll notice the lower explosive limit for diesel fumes is 0.6% of atmosphere, and the upper explosive limit is 7.5%. If the concentration is anywhere between those two points, diesel fumes can explode. That's actually a wider range than gasoline. Gasoline's lower limit is about 1.4 or 1.5%, and its upper limit about the same as diesel. So diesel fumes will explode at a noticeably lower concentration. What makes diesel safer is that it has a higher flash point, which means it's less likely than gasoline to vaporize and create fumes to begin with -- but the fumes are no less dangerous. You go ahead and weld on diesel tanks all you want. But if I'm ever around while you're doing it, I'll be having a beer and watching from somewhere across the street.
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
| Squark--squark--squark--thats the sound of a chicken --ha ha h ---please forgive my sense of humour. Yeah thats where most people are. If you exhaust carbon monoxide gases from the cars engine the tanks do not explode. These jobs are done, new tanks are not always purchased. There are shops that specialize in cutting open fuel tanks to clean. The cap and anything else you can do to open the tank is done -- It also depends on how hot it is, if I was in Alaska or the Sahara desert. If they do blow its only a whooosh out of the cap, its a very poor combustion. |
| How Is Water Getting In My Gas Tank? | Noob2U | Gas Engines | 33 | 08-09-2009 10:40 PM |
| cleaning varnish scum from fuel tank | scveach | Gas Engines | 19 | 06-20-2007 06:43 PM |
| Gas tank cleaning | isby | Powerboats | 2 | 08-23-2006 08:46 PM |
| gas tank grounding | acemotorcar | Electrical Systems | 5 | 04-17-2006 10:04 AM |
| Is Aluminum Gas Tank Ok ???? | MATTRESS GUY | Boatbuilding | 3 | 02-07-2005 12:18 PM |
