Old 01-18-2012, 02:31 PM
kenrahe's Avatar
kenrahe kenrahe is offline
Sunseeker
Rep: 24 Posts: 85
Switching 3.0l distributor
One motor that i'm going to be using has the delco est distributor can i switch the point distributor that I have on my parts motor with no wiring problems the reason I thinking of doing this is that the delco one has two plugs at the bottom of the cap and can't seem to find what went into the second plug the first one plugs into the coil is the second one just for a tach hookup...
Old 01-18-2012, 10:18 PM
Rep: 1493 Posts: 7,447
Is this a Mercruiser, a Volvopenta or a OMC?
Old 01-19-2012, 02:14 AM
kenrahe's Avatar
Sunseeker
Rep: 24 Posts: 85
A Mercruiser
Old 01-19-2012, 06:30 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
The electronic version has a 2-wire connector dangling from the housing. Merc says in the manual it is for diagnostic purposes only....
I never bothered to check how it is wired internally.
Old 01-19-2012, 08:13 AM
kenrahe's Avatar
Sunseeker
Rep: 24 Posts: 85
But can I switch to points dist.with no problems
Old 01-19-2012, 09:16 AM
CDK's Avatar
CDK CDK is offline
retired engineer
If that's what you wish, yes you can.
Pos and Neg Battery switching Frosty Electrical Systems 23 07-18-2011 08:57 AM
switching from hand layup to infusion, what am i forgeting scphantm Fiberglass and Composite Boat Building 16 12-14-2010 07:23 PM
Switching out cabin Hooligan971 Boat Design 0 07-03-2010 08:34 AM
switching motors toddpoor Boat Design 3 04-02-2007 10:10 AM
Battery Switching Schematic 67-LS1 Electrical Systems 6 12-28-2004 08:52 AM
