Old 05-25-2009, 02:19 PM
jabroni jabroni is offline
Rep: 10 Posts: 8
Smoking FORD 302 CID
Hello All, I just purchased an older Revel Craft Cruiser with a reverse rotation Ford v8 302cid engine. I have been restoring the boat, everything needed replacement except the hull and engine, or so I thought. I finally got it in the water this weekend and slowly got the motor up to cruise at 2500 RPM. After 20 minutes on the water I noticed smoke coming from the starboard side of the engine. I thought it was just residue oil or grease burning off the block or manifolds. After an hour it kept smoking and I finally returned to the marina. Please advise.
Old 05-25-2009, 03:21 PM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
Could be something as simple as Too Much Oil in the Pan? Probably best to do a compression check. All cylinders should be within 10% of each other.
Most likely is a stuck or broken piston ring. Did it heat up after running for an hour + ? How was the oil pressure?
Old 05-26-2009, 03:34 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
As I understand it, the smoke is in the engine bay and not coming from the exhaust. In that case, oil level or worn cylinder parts cannot be the cause.
Assuming you are a lucky guy, the tube or hose for the crank case ventilation is loose, cracked or missing, so the engine cannot suck it in through the flame arrestor or air filter. So it is a simple external problem.
If on the other hand, you attract bad luck, the starboard cylinder head may be cracked, or even the block, making things much more serious.
Old 05-26-2009, 04:08 PM
Rep: 10 Posts: 8
Hmmm
Yes, the engine only smokes after is warmed up a bit. It could be the pvc valve or maybe gaskets are bad and when the block heats up, it expands and those leaks become apparent. The water temp isnt bad, it heat up to 160 degrees and then suddenly drops down to around 100, Im guessing the thermostat kicks in and lets in fresh cold water. I havent had a chance to do a compression test, I'll try sometime this week and post the results. Thanks guys.
Cooling problem Ford 302 san Propulsion 38 05-30-2011 12:44 AM
ford 302 to a 270 stren drive bayliner83 Sterndrives 3 08-20-2009 09:33 PM
Mercruiser Ford 302 blow-by daniel240 Propulsion 6 02-11-2008 09:10 AM
302 Ford/Mercruiser safesheet Propulsion 0 01-08-2008 02:30 PM
Fuel Pump/Merc 302 Ford sledrider_ny DIY Marinizing 7 09-12-2004 11:28 PM
