Old 03-27-2007, 09:53 AM
saabster saabster is offline
Rep: 10 Posts: 15
rochester carb prob
hi new guy here .hope someone can help.ive just fitted a rebuild quadra jet carb on my 5.7l chevy.i'm now finding it hard start,when it dose start it will only tick over.any kind over throttle put on just kills the engine.i found that if i disconnected the linkage to the white plastic pull off?,the engine would rev.i opened up the carb and it as 67jets in it ,i should also mention the engine has larger valves,flat top pistons and ahigh lift cam any ideas would be greatful.
Old 04-03-2007, 08:21 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
carb probs
sounds like you have a vacuum leak or are running too lean. Is the choke working correctly? Once it warms up does it run better?
Old 04-09-2007, 01:17 PM
Rep: 10 Posts: 15
carb prob
thanks kenj will have alook. cheers.
EFI vs Carb? diello Powerboats 33 10-30-2007 09:58 AM
evinrude carb jetting pcriger Outboards 7 08-27-2007 12:38 AM
popping back through carb lee armistead Gas Engines 5 09-19-2006 09:18 AM
Mercury carb swap help please. rvBilly Outboards 0 07-04-2006 12:44 PM
carb to efi - howto Guest Powerboats 15 01-08-2005 11:36 PM
