| RePower Luhrs 31' Its time to re power my boat. It has a pair of 1993 5.7 SB 260HP, one RH rotation, one LH rotation. Id like to put in more HP, but all the newer Vortec motors with roller cams, aren't available in RH rotation. I've seen 383 stroker marine long blocks available in RH or would these be too radical a swap? I have Borg Warner trannies, if I could find a reverse rotation transmission, I could have my pick of motors, but a RR transmission is no longer available in a 71C-17 Velvet Drive. Which way to go? |
| 71C transmission can turn either way. You can set the pump for whichever rotation
__________________ Gonzo |
| the question is how to get right hand engine CW to repower otherwise the boat will end up with both props rotating the same way
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| re sale wise get 2 new trannies that can do either output so you can them have late model engines
| Reverse Rotation Transmision |
| Then you can get either a Twin Disc or a Liberty transmission.
| transmissions Thanks, I.ll check those out. |
| 1988 Luhrs | DOSGATOS | Gas Engines | 3 | 08-04-2010 06:00 PM |
| What should I put in a 25' Luhrs flybridge? | mongo75 | Diesel Engines | 7 | 10-12-2009 09:15 PM |
| 35 luhrs alura | fish1860 | Powerboats | 3 | 03-12-2007 12:50 AM |
| Question on Luhrs Allura 35 | firepiper | Boat Design | 0 | 08-08-2006 10:27 PM |
| Michael Peters - Luhrs 78 | Willallison | Powerboats | 2 | 08-18-2003 06:10 PM |
