| Quadrajet carb woes, help! Hi: I have a Rochester Quadrajet that recently started leak fuel all over the engine. The engine has previously run fine with a few hundred hours on it. Upon inspection, this fuel leakage/overflow is emanating from the point where the accelerator pump piston passes through the top of the carb body. (Please see the blue arrow). This happens 5-10 seconds from startup. ![]() I've already replaced the accelerator pump with a new one from a rebuild kit. but this didn't fix the problem. What I've done/tried since the problem began: 1. replaced the accelerator pump (including the rubber "cup") assembly with a new one from a rebuild kit. This did not help. 2. Adjusted the float level in an attempt to limit the amount of fuel entering the fuel bowl. Checked for a "sticking" float. The float appears to be intact and operating correctly. 3. checked needle valve for goop/sludge/etc. that would keep it from closing properly when the fuel float floats "high" because there is adequate fuel in the bowl for that exact moment. The engine did sit over winter, but has been started occasionally and run, and this appears to be a new problem, rather than one which has gone on for a while and is just now being noticed. I'm at my wit's end. I'm scared to death to have free-flowing fuel pooling up on my engine and on top of the intake manifold, spilling down to who knows where. What am I missing? Thanks in advance! |
| My experience with Quadrajunks has been that it is much cheaper and easier to yank it iff and replace it with a Carter/ Edelbrock, or Holley if you must. Anything is better than Rochester.
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| If you have a rebuild kit, it would be better to change all the parts, including the needle valve. Adjusting the float level lower will make the engine run lean. I suspect the needle valve is leaking and not shutting the fuel.
__________________ Gonzo |
| Quadrajet carb woes, help! have you put epoxy or JB Weld on the ports on the airhorn? I had the same problem, the gas was going into the crank the engine runs rough, black (rich) smoke is going through the tailpipe and vapors are visible from the carb after I turn it off. After putting JB weld on the air horn ports that leak under a vacuum and should of had plugs on them, but sometimes the vacuum is so strong they are sucked out. And after changing oil and oil filter, and JB Weld, I seen no more gasoline on my intake manifold. Don't get rid of a perfect Quadrajet, it is more complex and powerful, and gives you better gas mileage. |
| quadrajets are great, have them on twin 1986 mercruiser MIE 340 big blocks. one has had a minor bogging problem twice, the other has run flawlessly for 20 years with 1160 hours on the engines. |
| Do you have a metal float or a black plastic material. If metal you can shake it to see if any gas has leaked inside the float. If plastic, replace it with metal. Over time, dry gas and stabilizers will disolve the plastic surface and allow some gas to be absorbed into the float material. It doesn't take much to decrease the buoyancy of the float. If the float doesn't have enought buoyancy, it can't hold the needle down. The part number for this float should be Sierra 18-7201 or GLM 77220. Hope this is your problem. Regards, Eldon |
| Perhaps you could exchange the carb with a competant rebuilder, that way if there is a continuing problem their warranty policy should protect you. |
| hi manzantia did you resolve the problem with the fuel leaking ?,as my rochester has strated doing the same thing! |
| hi manzantia solved the problem .by changing the float neadle,main jet and the acelerator pump piston.hope this helps.saabster |
| EFI vs Carb? | diello | Powerboats | 33 | 10-30-2007 08:58 AM |
| Quadrajet Adjustment | ChillrMn1 | Propulsion | 53 | 06-25-2006 05:27 PM |
| New Genset Woes - Who To Advise re Design Defect? | elmaceh | Open Discussion: All Things Boats & Boating | 8 | 04-21-2006 07:26 AM |
| where to pruchase carb parts. | a3eyedfish | Propulsion | 1 | 03-15-2005 09:01 AM |
| carb to efi - howto | Guest | Powerboats | 15 | 01-08-2005 10:36 PM |
