#76
#77
| You are generous. |
#78
Where diesels require after treatment (which is expensive and maintenance intensive) turbines need none of that. While many marine diesel engines are unrestricted in their emissions, a large diesel capable of meeting Tier III standards is going to need a urea system to reduce emissions, and that is expensive. A reciprocating engine running on diesel fuel is a smudge pot compared to a modern turbine. |
#79
| Yellow, While we're on the topic: Why are turbines (exhaust) so stinky? -Tom |
#80
Depending on the fuel, turbines also have higher emissions on startup. That is because you have to get a combustable mixture in the air stream before it lights off and combustion is poor as the engine is coming up to idle. That results in a good bit of unburned fuel going out the exhaust before it gets up to idle. That is also one reason that turbines fell out of favor with the auto companines. It was difficult to control startup emissions and that is where 90% of the exhaust emissions from a typical engine happen. |
#81
| Well that makes a lot of sense as they (Single and Twin turbo-prop Otters) idle on taxi here all the way across the harbour and if you're down wind, pee-yew. Thanks Yellow and OP for the hi-jack. -Tom |
#82
#83
| DCockey, I just worked backwards from FastFreds #71 post. 1.18gph @ 7.13lbs/gal = 8.41lbs which divided by 0.36lbs/hr/hp gave me 23.36hp, i dont know if this is correct,which is why i was asking. I thought this was a good example for me to try the math since we ran light in one direction and under load the other way. Steve |
#84
Do any turbines in any use have to meet emissions and who controls that?
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
#85
| The same turbines are used in power plants, which have very strict emissions controls, at least in EU. They have to be measured for particles, NOx, SO2 etc. Modern turbines meet these without additional equipment like electrostatic precipitator (ESP) or flue gas desulfurization (FGD), which many other types of power plant need in order to meet the emissions control. |
#86
| Reformulated fuels also have a huge influence of how clean the emissions are.
__________________ Gonzo |
| High torque engines | Boston | Boat Design | 87 | 05-02-2009 12:10 PM |
| High rpm jet drive | danrabe | Jet Drives | 6 | 10-21-2006 10:19 PM |
| ultra-low rpm prop. | SolomonGrundy | Propulsion | 10 | 11-01-2005 08:42 AM |
| Concave hull / Low RPM | BigD | Powerboats | 38 | 07-04-2005 06:00 PM |
| low rpm diesel | ron17571 | Propulsion | 8 | 03-24-2005 08:45 PM |
