| Performance curves BBC I am trying to get my hands on some performance curves for a 7.4 (454) marinized by Volvo. Specifically Engine # BB740 A SW 410012601586817 8:1 compression. Thanks for any clues
__________________ If this is tourist season, why can't we shoot them? |
| I will email to you performance curves for a crusader 454. Should be close enough. let me know john |
| John, That would be absolutely wonderful, I greatly appreciate that. Thanks
| 454, 320 or 350 hp I'd like a set too. Mine are 350hp (on the valve cover) w/ Q-jet, but I keep hearing 320hp. Whats the difference? I know on the 318 Chrysler the difference between 195 & the 225 hp was a 4 barrel carb. Fred |
| Hey Joe, I have that data on another hard drive that is currently not hooked up. This is a super place to get motor info. They are drag boat guys and some of them are extremely knowledgable. http://www.performanceboats.com/html/forums/ Generally speaking many of these 454 motors are quite similar in real horsepower despite advertising claims. The drag boat guys concencus is a 320 hp motor might make 280 on a good day. Look at your compression ratio for clues. I will try to get those curves for you but it will take a while. Meantime why not put all the specs of your motor up.
| hey joe I posted the curves on the other thread you posted on recently (prop size) in the inboard section its on page 1 as a .pdf attachment john |
| I watched a Mercruiser 330 ( 454 ci) on a dyno in Australia years ago. It made 260+ horsepower and 330 ftlbs ....mercury dispute this. A 370 ( high performance 454) made 300+ and 370ftlb A 260 ( 350cu) made 220+ and 260ftlb (These were all with dry headers not the marine manifolds/risers from the engines) I also know a 260 and the old 225hp outboard pumped the same pressure on land & sea dyno... As mentioned above the v8's have very low compression so are not as potent as you think
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| bbc engine curves this type of comment does nothing to further anyone's knowledge. if you have run a 7.4l on a dyno post the results. it is unacceptable to claim a contrary posistion without providing data that is at least as precise as the data you are challenging. I'm just saying accuracy is important that's all john |
| I thought I was agreeing with Tolly? It was 20 years ago so sorry I dont have the sheets Where was the precise data I am challenging? I would guess Land & Sea might still have the data for production engines. But I think they just listed max dyno pressure if my memory serves me?
| here are performance numbers published by manufacturer. I posted some time ago to further a different discussion. john |
| Making Curves - is this one way? | kach22i | Fiberglass and Composite Boat Building | 35 | 06-02-2008 05:44 PM |
| Rhino Curves | jmedick | Software | 6 | 06-27-2007 02:34 PM |
| engine performance curves | jsh | Gas Engines | 4 | 12-12-2006 09:11 PM |
| Copenhagen Ships Curves | valgin2150 | Boat Design | 20 | 10-15-2004 10:14 AM |
| Ships Curves | Boat Design | 1 | 10-01-2002 11:05 PM | |
