Outdrive Oil
Discussion in 'Gas Engines' started by Poolboy, Jul 26, 2010.
  1. Poolboy
    Poolboy New Member
    Hi,
    I have a mid 80's Lazdays houseboat with 2 x 454's, with velvet drives and big beefy outdrives TR's maybe?
    I think the Velvet Drives take ATF - can anyone confirm if that is the case at what is best to use? I am really unsure about the outdrives. They have reservoirs mounted on the interior transom and I am unsure what they need to be topped up with! They have dipsticks and they need topped up. Do I use gear oil like SAE 80/90 or what? Should I buy the gold plated Quicksilver sterndrive oil. Nothing is marked anywhere?
    I did change the oil in these lovely big V8's and put in Full Synthetic - they are sounding great.
    Thanks for any help!
  2. gonzo
    Likes: 2,412, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
    Velvet Drives use Dexron III. The drives will depend on what they are. If they are Mercruisers then use GL5 85W90. You can use synthetic on both.
  3. Poolboy
    Poolboy New Member
    So DEXTRON III in the auto/velvet drive - thanks!
    So the actual outdrives - big suckers.. use general gear lube 85W90? I don't wan't to drain and refill.
    Thanks for your help!
  4. Poolboy
    Poolboy New Member
    I have a buddy with another houseboat (2 x 350's) and big out drives (with the electric motor driving a microswitch for neutral). It's a mid 70's boat and he has a broken gimbal assembly - where the hydraulic rams fit - any idea where he can get one/two? As I said we think they are maybe older TR's - any ideas?
