Old 05-12-2010, 02:50 AM
capt littlelegs capt littlelegs is offline
Rep: -67 Posts: 237
Originally Posted by rocket98 View Post
Don't try to rebuild that engine. Take the money and build a BBC. That engine will just run 4600-5000 rpm for awhile then it's gonna break again.
Rick Johnson
As I understand, it's running fine and isn't broken! What's a BBC... British Broadcasting Corporation?
Old 05-12-2010, 11:24 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
<Chuckle> BBC = Big Block Chevy.
-jim
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 05-12-2010, 03:13 PM
Rep: -67 Posts: 237
Ah, don't see many of those over here, at least not called a BBC.
Old 05-19-2010, 11:30 PM
rocket98 rocket98 is offline
Rep: 10 Posts: 2
The problem with the olds is that at any rpm above 4800. Too much oil is pumped into the heads and the crank bearing starve for oil. That means that the oil doesn't evacuate fropm the heads to supply the main bearings.
Old 05-20-2010, 06:00 AM
Rep: -67 Posts: 237
I should imagine this would be a relatively simple matter to restrict the top oil flow to a more suitable rate to prevent undue oil starvation. There may even be a limiting valve that's been overlooked. Also, increasing the oil level might help.
Old 05-23-2010, 07:56 AM
Hydro Phil's Avatar
Hydro Phil Hydro Phil is offline
Hydro Phil
Rep: 19 Posts: 15
There are oil restrictors that go in the block under the main bearings, Mondello Performance has these, I also have a 10 quart oil pan on my 455 in a jet boat, have been turning 5400 rpm for 12 years now with no oil problems what so ever Mondello Performance is California, he is the Oldsmobile Man when it comes to these engines. Makes & stocks all sorts of aftermarket parts for the Oldsmobile
Old 05-30-2010, 09:48 PM
tile69 tile69 is offline
Rep: 10 Posts: 5
OK SO....I have a 1971 shasta Jet Boat with a 365hp olds motor in it........OK so It runs pretty good so far..It starts pretty easy..Umm My question is though...I just changed the oil in it...I put 20 50 in it...I replaced the dipstick, It needed this bad, However when I did this I had to wait for the dipstick to arrive....Here is where I need some good old fashioned info....With the dipstick gone and an open hole in the block where one would b the engine got very very wet.....The engine since the oil change has not even got 3 mins of run time........(I ve been chasing wiring ghosts)...However I checked it today and it was pretty cloudy....NOT SLUDGEY but really cloudy and almost milky......Could this be from water seaping into the engine from the intense 3 days of rain...Thru the dipstick hole..There is more I also changed the Exahust Gasket becuse when I attempted to start it.Before this rain.While plugged into a garden hosen water SHOT OUT THE exahust gaskets on the Driver side...So I changed them....(NO MORE EXAHUST LEAK or water spraying)...Also after the heavy rain there was ALOT of water on the Intake Mainifold....And just looking at the Mainifold when its dry my first thought would be...WOW that needs NEW GASKETS....So Question is Where is the Water most likely coming From...SHOULD I CHANGE THE INTAKE GASKETS.... Also I have positve oil pressure Last time I checked but Not a staggering huge number.80 or 90 PSI right at starting.. around 60 PSI AT STARTING.IS this normal? When gas is applied it does go up.I think the sending unit is going I m not sure it..It sureges just a touch if I give it gas...NOT ALOT it never zeros out..Once i let off it goes back down to 60 or so PSI...IT Idles well and starts pretty easy... Three pumps and a turn of the switch and its going...idles about just under 800 nicely...........Is all lost or am I making a mtn out of a Mole hill.....Its also very Very rusty.....
Old 05-30-2010, 09:53 PM
Rep: 10 Posts: 5
Ohhh Also I m running a MSD 6AL with a built in rev limiter...That I will set a RPMS.....I m looking into changing out of the points and running straight HEI....ALSO I M CONSIDERING A SET OF Edelbrock Logs and squierel cages....150 bucks....I m looking for some good advice for this olds.....Like I said its a 71 WITH G heads and a F Block
Old 05-31-2010, 06:52 AM
Hydro Phil's Avatar
Hydro Phil
Rep: 19 Posts: 15
Personally I would change the oil & filter & see if the water comes back in the oil. Its possible the water got in the dipstick hole, running it 3 minutes would make it milky. Seems if the intake was leaking that badly, you would have a vacum leak & a terrible idle. As far as oil pressure, seems normal, cold oil will read higher pressure, as it warms up & engine clearances increase with temp, pressure will drop slightly, 20 psi or so. Start at 60 psi cold & 40 psi when warm is ok at idle & would increase with rpm.
  #25
Old 07-06-2010, 04:15 PM
pdswerld pdswerld is offline
Rep: 10 Posts: 8
here we go again
Sorry guys been busy since last post.
Update ran electrical, to include new gauges and all senders(replaced). LIKE A PRO. except 8 hours longer than a pro. Everything worked great. Even figured out oil and filter, new distributor and fuel filters before and after gas tank selector valve. new exhaust tubes, blowers and all the fixin's to dresser' up. We took it out 4 times so far and each time it ran beautifully. My dad recently took it on the Eagle River chain and must have sucked up some weeds pretty bad. The boat started acting up about 20 minutes into the ride and he said he pulled out some pretty big weeds. Since then, this was yesterday, he's opened up the small compartment in the Berkeley drive to clear the rest of the weeds out and even looked under by the intake grate and he says its clear.
It idles fine, oil's fine, but as soon as you go to give her gas, it runs like crap or just doesn' t go like it should. I don't know how long he was driving with the drive clogged but as soon as it started acting up he checked it out
  #26
Old 07-06-2010, 04:27 PM
Rep: 10 Posts: 8
and then there was smoke
dad just called and said there is black smoke coming out of it now... I have no clue what the heck is wrong
  #27
Old 07-07-2010, 09:36 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
You'lle need to go up the M1 a fair ways to Bradford. 70,000 sq foot of American cars and engines for boats too.
Im sure you will get BBC from there. I bought SBC 30 years ago from them.
http://www.rodleymotors.co.uk/
455 Olds Oil babs240sx Gas Engines 2 05-27-2010 11:45 PM
455 olds to be rebuilt MF455OLDS Powerboats 5 07-25-2009 05:54 AM
olds 455 chevyrat619 Gas Engines 14 05-25-2009 08:27 AM
1974 jet w/455 olds Miller83 Powerboats 4 03-07-2009 12:50 AM
455 Olds & Berkeley Bdt1967 Jet Drives 3 10-06-2008 10:18 PM
