Old 09-02-2009, 05:39 PM
ruso17206 ruso17206 is offline
old mercruiser engine serial numbers???
hello!!! i am juan from argentina, and i need your help.
i have old mercruiser engine 260 from ī80. where is the serial numbers??? this donīt have stickers located near the starter, by the flywheel housing; or, on the rocker arm or flame arrestor cover, and is separated from the transom plates and the sterndrive. is possible the numbers engraving, coined, or printing in the block???
thanks, and sorry for my bad languages.
Old 09-03-2009, 04:01 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,144
Once the decals are gone and the warranty card is missing, there is no way to find out the serial numbers from the drive or transom plates.
The engine may have a small metal tag riveted near the main circuit breaker with only the word Mercruiser and a number on it.
Old 09-03-2009, 12:44 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
Whats the reason you need to know?
If its a EOE exhaust with points is basically one serial number range or
if it a COE with electronic ignition its another range
End Outlet Exhaust
or
Centre OE
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
YSE Engine Serial Number Location Psychobob Diesel Engines 0 05-26-2008 05:59 AM
140 mercruser engine c.i.d. identificafion by engine serial number ggsimpson Gas Engines 0 11-18-2006 11:39 AM
mercruiser inboard engine mikebhunt Inboards 4 08-09-2006 12:57 AM
3.0 Mercruiser Alpha one Test Numbers Preformer 40 Boat Design 0 07-23-2006 12:08 AM
mercruiser serial number help manyolkars Propulsion 3 12-26-2004 01:30 PM
