Old 02-06-2011, 02:51 PM
lcdaniels6 lcdaniels6 is offline
Rep: 10 Posts: 4
oil filter location
i have a 1999 ebbtide volvo penta 4.3 gl were is the oil filter located
Old 02-06-2011, 03:44 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
It might have been placed in a remote location which is done for several reasons. If it is not attached to the block then you have your answer. You then just get the approiate hose and return and mount it where you want to for easy change.
Old 02-06-2011, 04:21 PM
Rep: 10 Posts: 4
thanks for the info i found a manual for this engine
Old 06-06-2011, 02:58 PM
Rep: 10 Posts: 4
i have a volvo penta 4.3 gl what type of oil should i use synthedic or non synthedic
Old 06-06-2011, 03:28 PM
Rep: 1493 Posts: 7,447
Synthetic is much better. It will last three or four times longer between changes, so it ends up being cheaper.
Old 06-06-2011, 05:03 PM
Rep: 10 Posts: 4
Thanks gonzo that helped a lot
Larry
Old 06-07-2011, 06:30 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
Oil choice depends on how you use your boat. If it is just for summer use, then regular oil is fine, change it when you put the boat away for the winter. If you are using it year round, then the synthetic makes sense.
Air Filter needed for pathfinder diesal kelldog Diesel Engines 5 05-05-2010 06:33 AM
Need help finding a oil filter relocation kit. bntii Diesel Engines 17 08-25-2009 11:03 PM
the best fuel filter for gasoline engines naturewaterboy Gas Engines 26 08-10-2009 02:50 PM
Need Assistance from HP Filter Experts... d_assassin Sailboats 2 08-04-2006 03:29 PM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
