Old 10-05-2009, 04:54 AM
Rep: 494 Posts: 3,842
If the firing order is on the intake manifold, it could just be from a reverse turning engine. Crank it and see which way it turns.
Old 10-05-2009, 08:45 AM
Concealed45 Concealed45 is offline
Rep: 10 Posts: 9
Do you mean yhe manifold could be from a different engine and the wrong firing order is on it ? Wouldn't that be funny if thats why he has not been able to get it to run !
Old 10-11-2009, 09:16 AM
broke_not broke_not is offline
Rep: 10 Posts: 23
Marinized engines have Stainless exahust valves
Marine engines can have stainless steel exhaust valves. They aren't *automatically* equipped with them.
Old 10-11-2009, 09:53 AM
The firing order should be standard with a sterndrive. Unless this is a very ancient engine, they all have Stainless exhaust valves.
Old 10-11-2009, 11:42 PM
Rep: 10 Posts: 23
When you stop the engine the exhaust is under water so you get some steam backing up.
So what happens when you shut the engine off and it stops with several of the exhaust valves open? Where's the steam going to go? It's going to travel right past those open valves and right into the combustion chamber/cylinder.
I suspect that the marine engines that do use stainless or inconel, (and no.....they do not all use stainless or inconel), use them for their ability to withstand higher temperatures for longer periods.
Total noob. Small plywood sailboat questions. unseen wombat Wooden Boat Building and Restoration 23 07-27-2009 08:22 PM
NOOB with many questions Bazzgurl26 Boat Design 44 07-06-2009 12:22 AM
Is it possible to swap my motor (1969 volvo penta) into a older tempest niv5674 Sterndrives 1 02-04-2008 04:41 PM
volvo 280/ 270 swap questions. lilmandavis Inboards 2 01-10-2007 12:05 AM
Noob questions OMA-T5 Open Discussion 4 02-17-2006 10:08 PM
