Old 10-27-2011, 08:58 AM
b_o_a_1000 b_o_a_1000 is offline
no oil
Hello I am a new member today. My ? is My 1969 350 engine is making clacking
noise. Oil pressure is 40 PSI,Good oil flow on Right side push rods, on or almost no oil from left side push rods. thank you
Old 10-27-2011, 11:21 AM
Frog4's Avatar
Frog4 Frog4 is offline
Proletariat
Rep: 12 Posts: 150
clogged oil passage(s) ...
use an air compressor and needle tip air nozzle to blow them out or use a vacuum pump to pull it out ... and change your filter ...
Old 10-27-2011, 06:32 PM
Rep: 1493 Posts: 7,447
Also, flush the engine before changing oil.
oil jollyricard Diesel Engines 11 12-27-2010 11:50 PM
electric oil pump for oil changes and priming simon Diesel Engines 13 11-14-2008 05:54 AM
How do I change my oil? Brylk1830 Outboards 4 06-22-2008 03:14 PM
Oil? Dan Currie Sterndrives 1 08-14-2007 11:27 AM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
