Old 02-19-2011, 08:25 PM
big570bear big570bear is offline
Rep: 10 Posts: 4
need spec information 1971 olds 455
doing a compression test on my 71 olds 455 , been trying to get a handle on what the minimum psi should be per cylinder?????????? if anybody happens to have that on hand please give me a shout. thank bear
Old 02-20-2011, 05:44 AM
Rep: 1493 Posts: 7,447
It depends on the compression ratio the engine was built to. Assuming it is no more than 9.5:1, the minimum is about 125psi. It may start under that but will show a pretty worn engine. Also, do a dry and wet compression test. That will show if there is wear in the rings and pistons.
Old 02-20-2011, 09:41 AM
Rep: 10 Posts: 4
gonzo I'm sure it is 9;5;1 according to the information i have already received. thank you for your reply bear
455 Olds block engine jetboatjill Marketplace 1 07-03-2011 07:29 AM
455 Olds Oil babs240sx Gas Engines 2 05-27-2010 11:45 PM
455 olds to be rebuilt MF455OLDS Powerboats 5 07-25-2009 05:54 AM
olds 455 chevyrat619 Gas Engines 14 05-25-2009 08:27 AM
1974 jet w/455 olds Miller83 Powerboats 4 03-07-2009 12:50 AM
