| yes, mine is a ford. did you have any issues with clearance when putting the cover? |
| boat exhaust no i did not even with the center rise style i still had room when puttin my cover cover back on what kind of boat is it |
| i have a 1989 bayliner I/O engine, i am kind of new at this also i need to make sure it is the right thing before i blow my budget. yours is inboard or I/O i will try to contact seller for more info and specs |
| my is inboard its a 89 vip if yours is a 302 ford then it will work and that kit gives u literally everything u need |
| i appreciate your help, if you do not mind i will get back for more advice when ever i order the parts. |
| yep no problem feel free to ask me anything on that boat i completly ran through my hole thing and i mean the hole thing good luck feel free to ask me anything |
| one more thing, what about the water hose going into the manifold? did you buy a connector barb for the hose? and when winterizing, there are no drain plugs |
| omc they come with the hose adapters any they do have plugs u take out to drain them if i can get ur email i will send u some picks of wat mine looks like when they are put on so u have a better idea |
| i sent you private message with the email, thanks for the help |
| Rookie needs help with OMC Cobra | The Rookie | Inboards | 4 | 07-23-2006 09:51 AM |
| omc cobra 800 ... help!!! | mackie | Inboards | 2 | 07-10-2006 08:37 PM |
| OMC Cobra | erie1 | Powerboats | 1 | 06-22-2006 03:09 PM |
| Omc Cobra tools | jokey1 | Powerboats | 0 | 05-17-2006 12:11 AM |
| Swap 302 omc for 351windsor omc king cobra outdrive | allen | Powerboats | 6 | 04-11-2006 12:10 PM |
