| milky oil.. yup again.. hey folks i came across an old thread that lead me to your site..via google.. i have a stern drive boat with a 250 h/p sbc 350 ci engine, i got the boat and the manifolds were pushing water into the engine, i just changed the manifolds, emptied out the old oil andfilter, and put in new oil and a new filter ran it for about 15 mins and i noticed the oil is milky white again... i imediatly went into a panic and i am worried thaty there may be a bigger problem.. but now i see perhaps a few more oil changes may be needed?? perhaps there was still a fair amount of water still in there?? any one have thoughts?? some one mentioned flushing the engine with atf....as in atf the traNSMISSION FLUID?? this is my first boat and so far i havent even had it in the water yet... im bummed out.. can some one shed some light on what i should do?? is there hope?? how do i go about flushing the water out of my engine? heat up the motor? the drain? how many oil changes? what do i use to flush,and how do i do it? please help! |
| Local fishermen here fill their submerged engines with diesel fuel to the brim, crank them by hand a few times and drain them (through the plug, not with a pump). It is quite messy, but all the water collects in the oil pan and comes out with the diesel fuel. My personal choice would be to use a can of garage cleaner, which is white spirit with a detergent as an additive. It mixes well with both water and oil and forms a stable emulsion you can pump out. Transmission fluid is also hygroscopic and can do the same job, but it is expensive and cannot absorb more than 0,5% of water. If after this evac procedure there still are signs of water in your engine oil and the engine has reached a decent operating temp., you may safely assume there is still water entering.
| True the motor could possibly not getting up to its proper running temprature and the moisture is condencing inside the motor do you have a heat exchanger and thermostat in the motor?? Check if its working and see what the temprature is meant to be , what about the dash temp gauge is it low,or medium or only works when the motor is underload ??. CHECK with an oil company about using hi detergent DIESEL engine oil in you motor !! This oil is designed to clean and hold the gunk in suspension so it will get to the filter and stay there . I always used it in my old petrol inboard years ago and the motor was always clean as a whistle inside . ![]() |
| is it running hot enough?
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Milky Vinylester | mikereed100 | Materials | 15 | 02-11-2009 01:07 PM |
| milky oil | crispy | Gas Engines | 38 | 01-14-2008 09:20 PM |
| Milky outdrive oil Volvo-Penta | jflongwell | Sterndrives | 5 | 12-19-2007 09:16 AM |
| I have Milky oil | chef2b86545 | Gas Engines | 28 | 06-21-2007 07:49 AM |
| Mercruiser 350 Leaking Manifolds and Milky Oil | Scarab26 | Sterndrives | 4 | 04-27-2007 02:46 AM |
