Old 07-18-2009, 08:18 PM
jabroni jabroni is offline
Rep: 10 Posts: 8
Mercruiser 888 (Ford 302) Stalls at 3000 rpms
So I purchased an 1973 Century Raven with a Mercruiser 888 I/O (Ford 302) and ran fine the first few outings. Soon after it started stalling around 30 seconds after getting on plane around 3000 rpms. It was hard to start but eventually stalled again. We creeped back to the dock around 1000rpms, but slowly they started to drop and soon sputter and stall when it got down to 800 rpm. Would not start unless left for 10 mins. Again, and again I followed this till we got back to the dock. The next day, I tried to trouble shoot the problem, but it would not start at all. I thought that it was a fuel problem, but can easily see gas spray into the carb. and also tried my trusty can of starter fluid. I gave the boat a full tune-up, replacing plugs, wires, coil, distributor cap, points, condesor, fuel filter/water seperator, battery and everything else I could think of. Re-tuned the carb., and filled it with fresh fuel. Still, same problem. The carb is a 2 barrel marine carb from holley and looks like it was replaced not too long ago. I dont know what else to check. I tried the many safety kill switches but they all seem to operate correctly. I have heard of this problem before with other boaters on this forum but have yet to really find a solution, others believe it could be a bad tach., timing advance is offset, fuel pump, and breather valve. I am really unfamiliar with these and could use some advice. Please help. Thanks!
Old 07-20-2009, 08:35 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
Not sure why a bad tach would cause the engine to run poorly. Fuel pump not up to specs? Fuel tank vent line plugged? Sucking air into fuel system. Fuel tank pick up tube getting blocked by crud in the bottom of the tank or positioned wrong. Vapor lock caused by a fuel line getting too hot. If you have ruled out the spark issue by replacing everything then it must be in the fuel system somewhere.
Old 07-25-2009, 01:40 PM
Rep: 1397 Posts: 7,216
Is there power getting to the coil? Try a jumper wire directly from the battery
Old 08-01-2009, 01:44 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,359
Bad Tacho can definately stop the engine as its conected to the points side of the coil on that engine.
There is a filter in the fuel line where it goes into the carb, but I assume was cleaned if the carb was replaced.
If water went through the fuel system the fuel pump can corrode as it has a low spot that will hold the water.
The rotor button can also play up on those. I have replaced a few with problems as its not something you normally see.
The ignition does have a ballast resistor block but it is a wire built into the wiring loom on the engine, so a good test ( as mentioned above) is to jump the power to a B+ and see if it helps.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
tune up For Mercruiser 188/ ford 302 holorinhal Sterndrives 16 08-02-2009 04:36 PM
Normal operating temprature for Mercruiser 188/Ford 302 holorinhal Sterndrives 6 05-26-2009 03:13 AM
Mercruiser Ford 302 blow-by daniel240 Propulsion 6 02-11-2008 09:10 AM
302 Ford/Mercruiser safesheet Propulsion 0 01-08-2008 02:30 PM
Problematical Mercruiser Ford 302 (888) JohnF Propulsion 14 12-15-2004 06:25 PM
