Old 09-13-2008, 01:39 PM
Bayliner Bill Bayliner Bill is offline
Rep: 10 Posts: 2
Mercruiser 5.0 ignition coil cracks
I have a 2002 Mercruiser 5.0 Alpha engine. Recently while cruising at about 25mph I heard a loud metal tearing sound. Boat stopped and would not start. Found no spark and replaced coil which I found was cracked on the negative terminal side. Replaced coil with a new one and after a few hours it did the same. Another crack. Any ideas or suggestions?
Thanks
Old 09-15-2008, 11:49 AM
redtech redtech is offline
Rep: 22 Posts: 252
check the charging system to much voltage can cook the coil
Old 09-15-2008, 01:31 PM
Rep: 10 Posts: 2
Thanks, I will check it.
Hot coil?? JerryIkemire Gas Engines 1 06-27-2008 08:39 PM
'89 Mercruiser 5.7L Ski, no coil spark? Chris Whittley Inboards 9 05-25-2007 05:14 PM
mercruiser 170 224 ignition help crackerjack Sterndrives 3 03-09-2007 05:19 PM
HEI Distributor - Coil on Cap jgalt_Winner-28 DIY Marinizing 1 11-17-2006 05:52 PM
Coil and Ballast replacement James Francis Inboards 1 07-26-2006 04:55 PM
