Old 04-14-2010, 04:32 PM
sbarton661 sbarton661 is offline
Mercruiser 350 Exhaust manifolds blocked
My engine continues to overheat. I blew air through the exhaust manifolds and there seems to be blockage. What would cause this and why would both be blocked?
Old 04-15-2010, 02:48 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Open the drain cocks at the bottom of the manifolds. There probably will escape no water. With a thin object punch through the sludge: the black goo coming out used to be part of the manifold walls. Removal may take a lot of flushing.
Old 04-15-2010, 01:11 PM
Rep: 1493 Posts: 7,447
They are probably corroded. It is time for new manifolds.
Old 04-15-2010, 02:01 PM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
Your Problem may go beyond rust, sludge. If the motor has been repeatedly overheated, the interior of the rubber exhaust hose could be blistered to the point of causing a plug. This has happened to me
Aluminum exhaust manifolds an upgrade form cast iron manifolds? Red Tide Gas Engines 2 10-27-2009 01:16 AM
Where can i get water cooled exhaust manifolds. stika-v6 DIY Marinizing 7 10-12-2009 03:11 AM
Thoughts on marine exhaust manifolds TollyWally Gas Engines 1 04-18-2008 03:57 AM
Mercruiser 350 Leaking Manifolds and Milky Oil Scarab26 Sterndrives 4 04-27-2007 02:46 AM
Nissan- Infinity exhaust manifolds--who? Richard Petersen DIY Marinizing 0 12-16-2004 11:15 PM
