Old 08-03-2006, 11:36 PM
n0dih's Avatar
n0dih n0dih is offline
Rep: 10 Posts: 2
Mercruiser 302 Head Gasket?
A friend of mine has a 1974 Mercruiser 302 Ford that needs a set of head gaskets. He has a couple mid to late 80's 302 car engines around. We were thinking of using the newer design heads for improved power or just cleaning up the old heads.
Either way, can we use an auto head gasket or is there something unique and special about a marine gasket?
The boat will only see fresh water, never salt water.
Thanks!!
Old 08-06-2006, 02:52 PM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
An automotive type gasket will work, but unless you have a closed cooling system, you should use a copper or stainless steel clad gasket since antifreeze is not present to help protect the gaskets from corrosion.
Old 08-06-2006, 07:46 PM
n0dih's Avatar
Rep: 10 Posts: 2
That makes sense. I figured auto parts would have degraded reliability.
Thanks!
Old 08-09-2006, 12:59 AM
Rep: 1397 Posts: 7,215
Marine heads have stainless exhaust valves.
transome plate gasket leaks tjmahon Propulsion 0 07-09-2006 12:12 PM
Cant get it out of my head Frosty Boatbuilding 8 08-28-2005 09:30 PM
Problematical Mercruiser Ford 302 (888) JohnF Propulsion 14 12-15-2004 06:25 PM
Use "Everseal" gasket for sealing... Nervous Boatbuilding 0 03-31-2004 11:45 PM
Head Location Willallison Option One 13 09-02-2002 02:17 AM
