Old 07-26-2009, 05:40 PM
chrisffg31 chrisffg31 is offline
Mercruiser 120 hard to start, stalls....
This is a project boat I picked up at auction for $900. It is a 1986 Starcraft with a Mercruiser 120 engine. When I got it the engine was frozen but I was able to get it loose by soaking the cylinders in Marvel Mystery Oil. It runs now but it's hard to start, idles rough and while it runs ok in my driveway in the water it will only take about 1/3 of the thottle and then it backfires, sputters and stalls. It acts like its not getting fuel. What do you think? Gummed up carburator? Clogged fuel filter? It will run to redline easily in my driveway but not in the water. This is my first boat - definitely open to suggestions!
Thanks
Chris
Old 07-27-2009, 06:53 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
You've bought a lemon for $900 and now you want us to tell why it isn't running?
Buy a manual for a boat, car, anything with an engine in it and follow the diagnostics program. Compression, oil pressure, carbs, ignition, the works.
That way you'll discover most of the problems that go with a $900 boat.
And when you've done all that and there is still something you didn't find, supply us with the correct data and somebody may come up with the right answer.
Old 07-27-2009, 10:40 PM
Rep: 2891 Posts: 8,798
Your engine and drive combination are covered in at least two different manuals that I know of, buy one.
I'd have to side with CDK on this, you had a frozen motor and rather then sort out the various issues, you just let the rusted piston rings slide up and down the rusted cylinders, of course with a fresh coating of oil on them and now wonder why it's not running right.
There are probably several things wrong with your engine and drive. Dare I ask about impellers, filters and other annually changed parts?
Old 07-28-2009, 02:05 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
Those are classic symptoms of bad points, but I don't know the engine, just the symptoms. If the engine has points, get some fine emery paper and reface them and gap them according to the specs.
Old 07-29-2009, 05:24 AM
Rep: 1397 Posts: 7,216
I'll bet you have no compression. It will run to high RPM with no load. You need a rebuild.
Old 07-29-2009, 11:25 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Chris,
As you can see, we have:
- One person who says to buy a shop manual, figure out everything that's broken, and if that hasn't scared you off, post everything you find and we might have ideas
- One person who says to buy a shop manual and pray that it hasn't already been cooked
- One person who thinks the innards are shot and it needs rebuilding
- (Sorry Alan, I seriously doubt that such a simple fix as ignition points will help an engine that was seized up and then freed with marvel mystery oil)
I don't think this bodes well for the future of this motor. By all means, pick up a shop manual and start doing the diagnostics it suggests, but keep in mind that you *might* have some pretty major internal damage on this thing.
Old 07-29-2009, 09:52 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
All of the above,-- but hey no one has a crystal ball.
If it came free by soaking in oil it was'nt that badly siezed.
Ripping stuff apart before knowing is stupid. By all means clean the carb and spent a minute or two on the points after all you would look stupid with the engine all apart and then find a cracked distributor cap.
Check it all out compressions N all.
Ditto on the why did you buy that when you dont know about stuff like that.
Old 07-30-2009, 12:08 AM
Previous Member
Rep: 0 Posts: 0
There are some really good bargains around at the moment particularly at the higher end of town. A work colleague is eyeing off a 52ft Beneteau for under AUD300k.
So USD900 might get something pretty good in boat and motor at a fire sale. Probably lacked some maintenance if the owner was in strife. Any power boat is junk unless you can afford to put fuel in it.
I agree with Frosty. It owes him $900. As much as you pay for a good course in engines I expect. Chris will get better experience, good or bad, hands on than sitting in a classroom.
Chris Ostlind has mentioned the value in second-hand boats right now on another thread.
Rick W
Old 07-30-2009, 12:20 AM
Frosty's Avatar
Rick a 52 Beneteau (ford of the boat world) at 300aus is not cheap.
Unless its last years model.
Old 07-30-2009, 12:30 AM
Previous Member
Rep: 0 Posts: 0
I do not know the year but he was impressed with the price. It will be similar to this one:
http://www.sydneyyachtingcentre.com....t=beneteau_new
It would need to be quite a few years old before you would think AUD300k cheap for something like this.
I will ask him if it is being advertised.
Rick W
Old 08-01-2009, 02:58 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
when you free up the pistons in the cylinders, how do you know the rings are free in the pistons?
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 08-01-2009, 09:28 PM
Frosty's Avatar
Compression test, wet and dry. Or should I say dry and then wet.
Diagnosis will save thousands. You would expect your surgeon to know where he was going before he sharpened his knife,--ok scalpel.
Old 08-02-2009, 12:15 AM
ha ha
good answer!
Old 08-02-2009, 01:41 AM
alan white's Avatar
Originally Posted by marshmat View Post
Chris,
No, though I tried. I was quite proud of my little guess. If you forget about the seize-up, I begin to sound rather clever.
Old 08-02-2009, 08:19 PM
broke_not broke_not is offline
Rep: 51 Posts: 51
Compression and/or leakage tests are fine, but you won't save thousands by spending a lot of time doing them on a simple GM four. I don't even see the necessity of dry and wet tests here. If you have a cylinder or two, (or three or four), that tests low with a dry compression test, the engine needs to come apart anyway. You may be able to hazard a guess as to why the compression is lower by doing both dry and wet tests, but the engine still needs to come apart for a definite look inside and subsequent repairs anyway.
A guy at work a couple of bays away from me will spend hours doing tests to ascertain the mechanical condition of an engine without diving inside. Then once the data is gathered, mini-meetings are held with other workers to see if everyone's opinions about what the data means coincides. Then after half the day is gone, some bolts finally get removed and some bits get taken apart. Often, many of the pre-disassembly guesses are confirmed.....often they are not. More often than not, other "surprises" are found inside that pre-disassembly tests would have never revealed.
I'm not saying these tests have no place, but I find them most useful in instances like trying to determine whether or not to buy a non-running machine in the first place. If I've already spent the dough and made the purchase though, I'll spend at most maybe a half-hour or so before the wrenches come out.
Mercruiser 888 (Ford 302) Stalls at 3000 rpms jabroni Gas Engines 3 08-01-2009 01:44 PM
Mercruiser 3.0L 1995 stalls after 1 min wmoss Gas Engines 12 08-27-2007 09:44 PM
85 hp Suzuki hard to start Thin water Outboards 5 08-08-2007 07:26 AM
new mercruiser 3.0 wont start boatn Gas Engines 4 08-22-2006 11:01 PM
Mercruiser 120 Replacement penguin Propulsion 1 04-23-2005 11:03 PM
