#31
carburettors and magnetos?? The industry is happy where it is no new entrants therefore no need to change and no EPA to go and change that
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
#32
| I don't think air-cleaners mean a thing to the gas engine. But to the Carb they sure do. I've seen the Venturi almost gouged out on engines that spent their lives with the same Air filter. Almost every carb that's been on a Marine engine operating in Salt water, inhaling salt Crystals, has a worn out venturi also. Thats where a lot of the loss of HP comes from in a Gas engine. A Venturi made of Carbide Steel would probably maintain its HP much longer than the Pot metal carbs would. Diesels are not bothered with little things like Breathing salt air. Having had the experience of rescuing an engine that was over heated repeatedly, I noticed the loss of HP. It started and ran OK, just soft on acceleration at working Rpm's. The Rings were cooked. They just wouldn't seal good at the higher Rpm's. I believe the extreme hi torque load on a Marine engine, all its life, does about the same thing to the Rings. They just don't seal as well once they've been cooked. All that load, all the time, is the same as cooking. Why Diesels don't suffer the same fate probably has something to do with oily cylinders. Just a guess there! |
| hydrogen powered marine engine | Bryan Campbell | Boat Design | 63 | 05-04-2009 01:34 AM |
| TIME to VOTE -What is "Hands Down" the best design software for the Marine Industry? | Chris Ray | Software | 5 | 02-03-2009 05:55 AM |
| Can any one help converting engine to marine | Odie | Jet Drives | 0 | 08-20-2007 02:05 PM |
| Used Marine Diesel Engine Wanted | blewett_john | Marketplace | 0 | 09-12-2004 07:43 AM |
| automotive engine -> marine engine???? | mechanical314 | Boat Design | 2 | 08-02-2004 09:47 AM |
