Old 06-19-2010, 03:42 AM
Marco1's Avatar
Marco1 Marco1 is offline
Rep: 240 Posts: 154
LPG powered engine
I was wondering if anyone has had first hand experience in LPG conversion on a boat.
There seem to be comon in Italy, UK and even Malta where LPG is half the price of petrol.
http://www.marinegasconversions.co.uk/
There's only one corner of the universe you can be certain of improving, and that's your own self.
Aldous Huxley
Old 06-20-2010, 05:18 AM
Rep: 1009 Posts: 4,506
The usual problem is range, as there are far fewer BTU per gallon .
The engine life is greatly extended as the fuel burns cleaner .
On many motor homes the LPG gen sets outlive similar sized diesels .
Old 06-21-2010, 10:02 PM
jonr jonr is offline
Rep: 57 Posts: 721
On cars, it takes a tank, regulator and new carburetor.
Old 06-22-2010, 03:10 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1819 Posts: 3,276
For a short time I converted a Glastron Bayflite to LPG.
Of course propane/butane is an excellent fuel for your boat engine. A smaller range is only true if you calculate by volume, by weight there is no difference with gasoline.
What made me terminate the experiment was twofold.
First there are no fuel stations for LPG near the waterside so you have to use bottles and carry these from the trunk of your car to your boat. That makes boating a lot less fun and is bad for your back.
The other problem is the flow rate. The biggest bottle you can handle contains 10 kg gas. Before you have used half of that, even on a sunny day the evaporation extracts so much heat that the bottle freezes over and there is no gas pressure anymore. The only way to overcome this is to put the bottle upside down, but without a dedicated construction it doesn't stay upside down very long. And after less than an hour you have to switch bottles already.
cogito, ergo sum (Descartes' credo)
Old 06-22-2010, 07:43 PM
Rep: 57 Posts: 721
Yes, normally the liquid is extracted from the tank and then evaporated with heat from engine coolant. Possibly someone could build a refueling trailer that could be moved to a dock where the boat is.
I'm in the middle of a partial CNG (compressed natural gas) conversion for a car - the tank (3600 psi) is heavy and doesn't hold that much.
Old 06-23-2010, 01:51 AM
Marco1's Avatar
Rep: 240 Posts: 154
Thank you for sharing your experience.
I must clarify that in Australia if the experiment has to work I could only use what we call "autogas" a mixture of propane and butane for automotive consumption that is priced below half the cost of gasoline. Propane in bottles used for cooking is priced well over the cost of fuel and therefore makes little sense.
Like in your case we don't have the LPG stations on the water like in Europe and so it is bottles. The bottles I had in mind are the forklift cylinders and I would have two hooked up to the same fuel line in order to minimise cooling.
Because I have the boat moored at my own jetty and I can drive right to it, the bottles transport when not fun shouldn't be a problem. Also, this would not work if I indended to go out for several days, and is only OK for day trips. I would keep the petrol tank.
Accepting the limitations of the exercise, my interest is in the accesories necessary to do this safely and that can not be borrowed from automotive conversion. I can easily find a technician that can install and convert the engine to LPG using all the car gear. What remains is for me to find a way to have positive ventilation and gas detectors with sufficiently high sensitivity.
How did you do yours ?
Aldous Huxley
Old 06-23-2010, 06:24 AM
CDK's Avatar
CDK CDK is offline
retired engineer
In my case I used standard gas bottles because they weigh around 25 kg when full, but I filled them from my own 1200 kg tank. I had (and still have) a 90 liters tank from a large Chevy, but lifting that one exceeds my capability.
I used a single stage Italian pressure regulator with electric "choke", connected to the cooling circuit between the engine block exit and the manifold input. It was very important to run on gasoline to warm up the engine or on LPG with no more than 1/4 throttle, otherwise the water in the single loop of the regulator immediately froze and the engine stopped.
To inject the gas I made a 2nd venturi placed on top of the carburetor, with a number of small holes just below the smallest diameter. The flame arrester came on top of that, now 35 mm higher. A single injection pipe is also possible, but this setup mixes better. In the hose from the regulator to the injection piece there was a crude limiter valve, a piece of pipe with a screw and a spring.
I didn't install any gas detectors, but there was a blower with its suction hose reaching almost to the bilge. I wired that directly to the ignition supply lead so it was always working while the engine was running.
My gas bottles were in the open.
In a cabin cruiser with gas bottles below deck I probably would install a gas detector near the floor, wired directly to the battery.
Old 06-24-2010, 08:46 AM
powerabout powerabout is offline
Rep: 719 Posts: 2,921
using an explosive fuel that is heavier then air in a boat?
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 06-24-2010, 08:48 AM
Rep: 57 Posts: 721
That's as crazy as using gasoline/petrol.
Old 06-24-2010, 09:02 AM
You would think that yet in the 80's when I was in business in Australia diesel powered boats were the highest risk catagory for insurance companies.
Hot turbos and fuel/oil under pressure....no boom but instant fire
Remember the old story of spilling fuel on your hot exhaust as you fill your motorbike and nothing happens..try it with diesel
The most dramatic demonstration is to put diesel ( rather than test fluid) in to an injector pop tester and hold a cigarette lighter in the injector spray....
Old 06-24-2010, 09:09 AM
Explosion proof DC electric motor....that must have cost a few dollars.....
Old 06-25-2010, 01:43 AM
CDK's Avatar
CDK CDK is offline
retired engineer
I really wouldn't know.
U.S. boat builders install such blowers to comply with regulations. Perhaps they use a closed electric motor, I would use an ordinary one because explosion risk at that location is minimal.
Old 07-09-2010, 03:33 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 389 Posts: 1,757
LPG powered engine
I do not know why boat builders are so fixed in their ideas about how you build a boat. If you design a boat to run on volatile fuel you design it accordingly. Does it Have to look pretty? Unfortunately the LAW dictates how you shall build a boat which restricts innovation. You can build a safe petrol or gas engined boat if you want to,but no one seemed to think safety important and follow the traditional methods.
tomkane
Old 07-09-2010, 04:40 AM
Marco1's Avatar
Rep: 240 Posts: 154
Traditional methods?
You lost me.
Aldous Huxley
Old 07-10-2010, 07:32 PM
tom kane's Avatar
The Rules (some) for Building a no-explosive boat.
Do not have gasoline or LPG tanks under the floorboards or in the motor compartment or inside of the hull of the boat.
Do not have any parts (carb,pumps,fuel lines) of the fuel reticulation system inside of the hull of the boat.
Do... have fuel storage and reticulation systems and crank case gases isolated from venting and draining into the hull of the boat.
Do... have all parts of the fuel system vented and drained outside of the hull.
tomkane
hydrogen powered marine engine Bryan Campbell Boat Design 63 05-04-2009
12:34 AM
Installing LPG in boats in America. tom kane All Things Boats & Boating 50 07-23-2007
10:42 PM
Engine-Powered Pinky ALowell Boat Design 3 05-01-2007
05:03 PM
outboard engine LPG conversion max50 Outboards 2 01-28-2007
01:02 PM
Bugatti engine powered boats rivaaquarama Powerboats 0 06-08-2006
03:26 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
