Old 08-20-2009, 12:48 AM
Mariner
Rep: 777 Posts: 1,543
K-Cycle or Christianson Engine
I attended a lecture by Dr. Christianson (SP?) in 1983 at Tech. school in
Calgary, Alberta, Canada promoting the K-Cycle Engine. It was developed
for a few years and then appeared to have died. It was a crazy idea but
resulted in much higher efficiencies than conventional internal combustion
engines. Cylindrical in form, the cylinders rotated like a "six shooter". The
pistons were opposed while the connecting rods travelled on a roller coater
looking guide simulating a variable radius crankshaft. Really hard to
discribe, but I am curious if anyone has heard anything more current about
the design.
Tom
Old 08-20-2009, 05:16 PM
Redtick Redtick is offline
Rep: 74 Posts: 17
Sounds like a variation on a swashplate engine.
http://en.wikipedia.org/wiki/Swashplate_engine
Old 08-20-2009, 07:34 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Tom,
I know the engine you're talking about- I haven't seen it personally, but a friend of a family member worked on a version of it (in Manitoba, I think), way back in the '70s.
The essence of the concept was reincarnated as the "OX2" in the mid-90s. It then vanished for a few years, and is now back in the news (see http://www.ox2engine.com ).
There's nothing particularly complex about the way it works; thermodynamically, it's a pretty standard four-stroke engine. What makes the thing so interesting is the strange, strange way that the engineers decided to package it- an unusual circular shape with axial pistons in a rotating engine block, and a roller-coaster-like fixed cam ring in place of a crankshaft.
This unorthodox geometry offers a few advantages: among them, a non-sinusoidal piston motion (thus extended dwell time, better control of combustion, improved efficiency), excellent intake and exhaust port flow, and the ability to fire each piston more than once per revolution. All told, the thing was giving dyno results in 1996 that were roughly on par with a stock GM 350ci small-block, despite weighing only 125 lb / 57 kg. I wouldn't be surprised if they've got the output up even higher now.
It ought to be fairly easy and cheap to build, too- there are only a handful of parts, most of which can be made with a standard lathe and mill.
From what I understand, the main problems were with sealing (similar issues to the early Wankels- I'm told the OX2 guys came up with some kind of full-floating port seal to fix this), raising capital, and getting it into production. Car companies, by and large, prefer to do their engineering in-house, and tend to be reluctant to embrace anything outside of what they're already familiar with.
Old 08-21-2009, 01:45 AM
Mariner
Matt,
That's the one! Interesting indeed. I'll check out the sites.
Thanks, Tom
Old 08-21-2009, 11:55 AM
Mariner
Change
Matt,
Wow, has the design ever changed. It looks like they dumped the opposed pistons,
they used to move towards each other, creating the compression chamber between them.
The clean cylindrical shape is gone too. It sure made a lot of sense to a bright eyed, college kid
in 1983 but it would certainly be tough to brake into the traditional internal combustion engine market.
Thank you again for recognizing my query. I've looked many times over the years for info
and always came up dry.
Tom
Deep Cycle Batteries. NEWENGLAND Marketplace 0 07-03-2009 10:55 AM
Cycle scaling for submarines models issac82 Boat Design 6 06-06-2008 04:38 AM
I want an electric Hydro-cycle! juiceclark Hybrid 20 04-08-2008 07:44 AM
wheel chair v. deep cycle oneboatman Propulsion 5 05-15-2007 03:53 AM
deep cycle battery's yipster Boat Design 18 06-14-2006 07:47 PM
