| Identify Mercruiser Chev engine I have acquired a chev mercruiser SB engine. Need to know which model and how much HPower it has. I found a service manual for 1978-84 models and it shows a distinctive shape stamped into each end of the heads to signify hp. It also shows a Mercury number stamped into the block. I cant find the number stamped into the block, and the shape stamped into each end of the heads is a block letter " L " laying anticlockwise on its back. This is not same as my book so must be different year. Looking for help with identifying motor please. |
| Without knowing if the engine is OEM and never been rebuilt it's a little tough. If you can get me the actual block casting number as well as the head casting numbers I can at least decipher a little for you. Being that you have ab early book, could you check my latest post "OMC /SBC Question" maybe your book will have the information I need. Thanks Gary |
| should be no Mercury # stamped into the blok, but there should be a tag on the side of the block where the flywheel housing meets the block |
| mercruiser inboard engine | mikebhunt | Inboards | 4 | 08-09-2006 12:57 AM |
| 3.0 mercruiser w/alpha 1 engine sputters when shutting off | bdonch | Powerboats | 4 | 07-20-2006 09:05 AM |
| 350 chev cooling system | nitrox1971 | Gas Engines | 1 | 01-19-2006 03:01 PM |
| Engine swap OMC to Mercruiser 4.3 | CreoleIII | Propulsion | 0 | 05-17-2005 10:36 PM |
| FOR SALE: MerCruiser 260hp gas inboard engine | lockhughes | Marketplace | 3 | 04-14-2005 11:08 PM |
