Old 05-31-2007, 01:51 PM
chef2b86545 chef2b86545 is offline
Rep: 10 Posts: 20
Haven't changed it yet but when i checked it back in april it was a little high.
Old 06-04-2007, 09:30 AM
Callinectes Callinectes is offline
Rep: 10 Posts: 6
A high milky oil level usually indicates that coolant has leaked into the oil supply. You said the level was a little high, if you have a cracked block, you would probably have twice as much oil on the dipstick as you usually have. Were you running a correct antifreeze mixture, or do you have straight seawater cooling?
Old 06-04-2007, 12:00 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Earlier he mentioned it was raw water cooled, and that the bilge had filled prior to the last time the engine ran, after which the oil hadn't been checked util recently, when the milky oil was found.
While not winterizing last fall, freezing raw water trapped in the block/head would not have mixed. This is milky oil.
I mentioned that water probably made it's way in when the bilge filled. I don't know how deep it filled, but I've had this same thing happen.
The oil, he said, was "slightly high", which I would take to mean not much water, and if bilge water, would not have had salt in it, so recommended cleaning the crankcase thoroughly and replacing oil, and checking frequently, as the source is most likely bilge water and not (unless a new problem has occurred) cooling water.
Old 06-19-2007, 02:49 PM
Rep: 10 Posts: 20
i took the head off and it looks like it was just the head gasket. But i have a couple more questions. Do i need to use a torque wrench to put the head back on? And where would be a good place to go to get all the gaskets that i need to replace after taking the engine apart?
Old 06-19-2007, 04:14 PM
alan white's Avatar
I don't see my first response, but wanted to add SEQUENCE of head bolt tightening is another thing you need to be familiar with. To be honest with you, if you can spend for the half hour or minimum charge to have the torquing done by a trained dealer mechanic, you can't go wrong. The rest is less critical, but pay close attention to manifold torque values too.
Alan
Old 06-19-2007, 08:46 PM
Rep: 10 Posts: 6
Look for an authorized Mercruiser or OMC dealer(I don't know what kind of engine you have) You will help the dealer out if you have the engine serial number with you(serial# on mercruisers is on the valve cover). You can get the gaskets there, and pick up a shop manual while you are at it. The shop manual will give you all the torque values you need, and it will give you the tightening sequence, as Alan mentioned, that is essential for a good seal. Get a torque wrench from Sears or Home Depot for about $70. As long as you pay attention, this isn't a big deal. However, I have found that the certified technician is always a safe bet. Good luck!!
Old 06-19-2007, 09:20 PM
alan white's Avatar
Did I post a link on another thread? There were two and I think that link is on the other. OMC parts.
I believe VIP auto parts rents tools like torque wrenches, if money is tight this week.
A.
Old 06-20-2007, 12:05 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Torque settings are for people that dont know when a bolt is tightened to its limit.
Just 30 years ago RR didnt give torque settings. (if you dont know when its tight we dont want you working on our engines ) They would say.
Tightening sequence is no mystery --Like rolling do-- start from the middle and work out (progresively).
Torque values are dependent on the size of the bolt the thread and the material you are pulling on.
At a guess I would say 60 to 80 foot pounds. thats 60(30kilo) pounds on a 1 foot long bar.
Even and in sequence is more important than the actuall torqe.
A wheel spider is an exelent head tightener.
Old 06-20-2007, 01:39 AM
alan white's Avatar
Frosty... those were RR car engines, not aircraft engines, right?
  #25
Old 06-20-2007, 11:19 AM
Rep: 10 Posts: 20
Thank you every one
  #26
Old 06-20-2007, 03:29 PM
SamSam SamSam is online now
Rep: 502 Posts: 1,684
http://www.iboats.com/Engine_Parts/d...view_id.268604
  #27
Old 06-20-2007, 06:39 PM
krush krush is offline
Rep: 10 Posts: 11
good luck. Sometimes those 4bangers just crack externally or blow out a casting plug (improperly called freeze plug).
I wouldn't rule out a cracked block though. It's almost guaranteed to happen if you do not winterize.
  #28
Old 06-20-2007, 10:35 PM
alan white's Avatar
Krush has a good point---- check the block out carefully. There are ways to do this beginning with visual inspection, and maybe someone knows further tests (dyes?). A small crack is a potential problem--- sometimes fixable if on the outer casting.
A.
  #29
Old 06-21-2007, 07:49 AM
Rep: 10 Posts: 11
sometimes on the 3.0 liters people get lucky like i said and only crack the outer part of the block (under the intake/exhaust manafold is a good place to check). If you crack the outside and not anything internal, it just means water leaks out of the engine...slap some marinetex or jbweld on that baby and make sure your bilge pumps work!
Internal crack means water gets in oil and you are bascially toast. In the small blocks it usually cracks in the lifter galley. Cast iron is strong, but brittle...it doesn't flex when ice expands!
Like I said, hope for the best, but you better plan for the worst.
milky oil crispy Gas Engines 38 01-14-2008 09:20 PM
96 evinrude 35hp White Milky out the Prop Exhaust lenwoodbluz Outboards 10 05-15-2007 02:46 PM
Mercruiser 350 Leaking Manifolds and Milky Oil Scarab26 Sterndrives 4 04-27-2007 02:46 AM
milky patches in clear gel coat still afloat Fiberglass and Composite Boat Building 3 07-22-2005 03:29 PM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
