Old 01-04-2008, 10:28 AM
Rep: 2891 Posts: 8,798
Jango is correct and unfortunately I've actually seen bodies flying through the air as a result of these types of explosions.
Which is why I usually go on a rant when folks come on the board as say things like "when I was younger we did this all the time" or "we use straight auto parts for all our marine assemblies and have no problems" etc. These people clearly are talking out their asses or haven't a clue, because once you see the bodies flying through the air, it kind of takes all the wind out of your argument.
Old 01-04-2008, 11:00 AM
martinf martinf is offline
Rep: 19 Posts: 51
Thanks guys,
The reason I ask is that I'm purchasing an old WWII boat that has a pair of Chrystler straight 8's (Royals). They have 2 carter carbs on each and I just assumed that they were standard carbs, but perhaps they are marine-specific? (based on what you said). It just never occured to me that they did anything different where the throttle plate bushings, etc. are, but it sure makes sense.
Just another reason why I'm leaning on re-powering it to some 371 detroit diesels. I don't want to flinch every time I turn the key (even with first running a blower). And speaking of, what about those blowers? I assume that any blower that's old is a standard dc motor with an armature and brushes that spark ocassionally....
~martin
Old 01-04-2008, 03:51 PM
The old marine blower motors would have had a "spark arresting" screen installed around the commutator end of the motor, preventing sparks from escaping.
Restoring a vintage engine has to be justified somehow. An old Packard 12 or other valuable engine is easy to quantify, especially in a full up restoration, where the authentic engine(s) is desired. Given a choice, modern engines are far and away better suited. Parts availability, reparability, etc. can make the selection easy at times.
Unless you have a desire for those old Royals, then you're much better off with a newer, easier to live with set of engines.
Old 01-04-2008, 04:49 PM
wooky's Avatar
wooky wooky is offline
Rep: 31 Posts: 18
Can You Say BOOOM ?
Yes, fumes are a concern because of the nature of gasoline, even though I have a bilge blower and the "air scoops" (don't know what the things are called, one faces forward the other rearward). The 3 times I took the boat out I didn't have the doghouse (engine cover) mounted but ran the blower anyway (good habit to get into). Judging from what information I have now, it seems that the previous owner of my engine installed an automotive carb, the vent doesn't turn back down onto the carb. This will be remedied before I take it out again, after completing the repairs to the hull (transom wood, stringers, sole-deck). After this fairly complete overhaul I should have a virually new boat that will last another 30+ years, and the best part is since I'm doing the work myself I'm estimating that I'll have less than 3 or 4 grand in it total.
Old 01-04-2008, 08:45 PM
Rep: 19 Posts: 51
Yep, that's true. I definately do have an engine worth restoring--an old Sterling Petrel with hardly any hours...doesn't really even need restoring--but these Royals are so much more common, I'm gathering. But, they came with a pallet full of new parts and I'll probably keep them for a while until I see what the fuel consumption rate is. They're pushing 54" props so it can't be very good!
~martin
Old 07-29-2008, 09:21 AM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
I remember working in a few when I was an an apprentice in the late 70's so they made it to Australia as did cars with them but I did grow up in an old marina and we had stuff there that was created since boating began..
Chrysler sterndrives with actual Chrysler legs
V4 OMC sterndrives
direct reverser Mercs
50hp V4 Evinrudes
MerCrusiers that you could wind the leg up sideways with a crank handle inside the boat.
MerCrusiers first diesel
MerCruiser with 409 Chevs
Here's the question of the day.
who can name the only 2 Mercruisers that came with twin carbs..
although 20 years apart( you will need to include performace stuff for one answer)
Old 07-29-2008, 09:47 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
Chrysler slant six`es usualy had the carb sitting on a cast set of ram tubes which helps increase torque.The starting point of ram tubes fitted to modern autos.Long ram tubes for low end torque and short tubes for high RPM torque.
tomkane
Old 08-07-2008, 08:34 PM
george allard george allard is offline
Rep: 7 Posts: 61
I saw a 1960s houseboat, about 40 footer, with twin 225 Chrysler's. The old thing had been completely restored and looked sharp.
Old 08-08-2008, 02:10 AM
BHOFM BHOFM is offline
Rep: 247 Posts: 458
I worked at an engine shop in the mid seventy's and we
did several of the engines, I think the marine engine
is a bit different than the car and truck version, I think
it had screw in core plugs for one thing and the distributer
hole was bigger, or something, that was a long time ago!
  #25
Old 08-08-2008, 10:01 PM
How about left hand rotation Chris Craft chev V8s driving from the timing case end, a volvo sterndrive!
  #26
Old 10-14-2008, 06:26 PM
2850 Bounty 2850 Bounty is offline
Rep: 10 Posts: 15
As many of us know, Chrysler at one time was big into Marine applications.
They joined right in with the B/W style trans adaptation.
Chrysler had an involvement with Volvo Penta early on as well.
Chrysler even labeled a hull as being "Chrysler".... I worked on one (Chrysler Boat) this past summer.
It used the Mopar 360 V-8 w/ the 280 drive.
All of the drive, with exception to a Borg Warner adapter/drive coupler, was Volvo Penta w/ the Chrysler name on it.
I'm not surprised to hear of the slant six being used back then.
  #27
Old 12-15-2008, 07:15 PM
forestfirepro forestfirepro is offline
M225 with Volvo 270
Hey there,
I have the same set up in a 19 1/2 foot Sangster. Chrysler M225 Slant 6.
Wondering if any of you folks know where the zincs are on this engine?
Thanks in advance.
Aaron
  #28
Old 12-30-2008, 02:46 AM
Chris Bretter's Avatar
Chris Bretter Chris Bretter is offline
Zaphod
Rep: 55 Posts: 45
hi Chrysler used a Badged Datsun SD22 motor at one time anyone heard of them
Great Source Of Rare Raw Materials grady Materials 0 06-27-2007 02:56 PM
Rogue waves turn out to be not that rare Kaa Boat Design 15 03-26-2007 10:32 AM
rare imp inca grey cat Powerboats 3 06-09-2006 03:15 AM
Rare Old Growth Marine Ply Available DucterJim Marketplace 0 02-03-2005 04:19 PM
Using EFI and marine setup vs. car setup curtis73 Powerboats 6 03-18-2002 01:45 PM
