| How can i start a inboard engine without the heat exchanger to see if it runs? I was wondering if anybody could tell me if there is a way to start a chrysler 360 engine without the heat exchanger on land. The heat exchangers were stolen off of both engines. I want to see if the engines run!!! I want to run them for a very short period of time ,probably for one minute to here them run. The heat exchangers are very expensive and i do not want to spend the money now. I am in the process of restoring a 1965 37' Egg Harbor Sedan and i do not think i will have it in the water this season. I basically want to see if the engines run or if they have issues and have to be rebuilt. They have not been started in 3-4 years. Any info would be appreciated. |
| pump water from hose in and dump it -- in others words just let it run through the block, forget the raw water side sorry someone stole your coolers, |
| run um First, if the exchangers were very old and had been used in salt water, you didn't lose much- they probably were due for replacement anyway. You can run the engines at idle for 2-3 mins without out damage, and any water in the jackets and heads is even better, but it won't be in the right places. The noise will be impressive, and there is a real fire danger- make sure there are no fuel leaks. A remote fuel cut-off and a good BIG fire system should be ready. good luck B |
| exhaust gas heat exchanger | singleprop | Diesel Engines | 11 | 06-29-2010 09:17 AM |
| Heat Exchanger Surface Area | Jellyfish84 | Inboards | 0 | 02-04-2009 08:57 PM |
| heat exchanger cleaning | kenJ | Diesel Engines | 2 | 12-15-2006 10:04 AM |
| Building a heat exchanger into the hull | djackson99 | Powerboats | 42 | 03-21-2005 02:15 PM |
| Building stainless heat exchanger | guest | Powerboats | 4 | 08-11-2004 03:46 PM |
