| Help Rebuild 350 The motor has been taken apart because I though it was frozen. After getting down to the block, removing the out drive did the trick. The out drive was frozen. I bought this boat without the engine starting because of this. So I assume that everything is ok. But I'd rather clean things up and upgrade for 300hp and possibly EFI It will be pushing a 1983 Wellcraft Aft Cabin 230. There serial numbers are not visible on this motor. The tag is rusted and unidentifiable. The only readable numbers are: BLOCK CASTING ID: 10066036 (350, 2 or 4 main, hecho en mexico) Head ID: 98417369 (GM11, hecho en mexico) Intake ID: 246250 10 Carb ID: Rochester Quadra Jet 1980 california model As far as I know, it's original. How can I figure the current/future HP/torque? What are some resources that may help me figure this out? (Software, Books, Websites) This is a project and a learning oppertunity. I'm a newbie at rebuilding but with some guide, it will be fun. Thanks!!! |
| Modern 350 Marinizing | LMannyR | DIY Marinizing | 45 | 09-24-2010 08:14 PM |
| Thoughts on water in 350 | yellowrosefarm | Sterndrives | 5 | 07-31-2007 11:49 AM |
| Marinizing a 350 | jaydubya999 | Gas Engines | 9 | 07-17-2007 08:08 PM |
| HELP with GM 350 timing | Dimitri | Gas Engines | 5 | 06-21-2007 08:56 AM |
| 305-350 swap | mtnrat | Powerboats | 10 | 08-10-2006 11:52 PM |
