Old 08-22-2011, 02:49 PM
Glastron77Qs Glastron77Qs is offline
Rep: 10 Posts: 3
Head removal Ford 302 marine
I have a 1977 Glastron and am 100% i blew the head gaskets. I am trying to remove them but the exhaust manifolds are a huge bother to get off. Also there are 10 bolts to get these heads off which i find weird. ANy ideas other than pulling the entire motor (im doing this in my own garage) as to how to get those exhaust maifolds out of the way so I can get the heads off would be greatly appreciated.
Old 08-22-2011, 10:50 PM
Rep: 1493 Posts: 7,447
The exhaust manifolds are bolted to the heads. You have to remove them first.
Old 08-23-2011, 12:01 AM
Rep: 3125 Posts: 9,399
Yep, the manifolds have to come off, as well as an assorted set of devices and brackets. Hit them repeatedly with penetrating oil (PB Blaster is good) for a full day (once an hour all after noon) and they'll eventually get soaked and break free. Also use 6 point sockets, not open ended wrenches or 12 pointers, you'll just round off the bolts with 12's and open ended wrenches. Of course an impact wrench is a handy thing too.
Old 08-23-2011, 12:44 AM
Rep: 10 Posts: 3
The answer im looking for is to the question of how can I get the manifolds away from the heads because the heads have studs and the manifolds hit the side of the seat which are fiberglass and I don't want to ruin
Old 08-23-2011, 12:46 AM
Rep: 10 Posts: 3
Im not asking how to remove them I know how to do that this is just angering me beyond belief because those studs are about one quarter inch to long
Old 08-23-2011, 02:49 AM
Can you provide a picture?
Old 08-23-2011, 05:25 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Is the seat molded in or bolted in? You may have to remove the seat, too.
Hoyt
Old 08-23-2011, 07:09 AM
In those installations,you have to take the engine out. The time you lose trying to do it otherwise is more than the couple of hours to take the whole thing off.
Old 08-23-2011, 08:17 PM
I vaguely remember the aft portions of the cockpit on those Gonzo. The aft sections of the deck cap form the seats and the lower half of the engine box. I also remember cutting some well placed access plates on one several years ago. A rectangular hole and cover on each side of the box. The cover was made from some 1/4" plywood and screwed back in place, after the deed was done.
Old 08-23-2011, 09:30 PM
I can see how it may be possible, but taking the engine out is only a couple of hours.
Old 08-24-2011, 12:24 AM
Agreed . . .
Old 09-07-2011, 11:13 AM
Chase_B Chase_B is offline
Rep: 76 Posts: 53
Glastron77Qs
the 10 bolts are arranged so that there is equal pressure on the head around all 4 cylinders,.sort of like putting a box over each cylinder, but the boxes over lap inboard ,..this is because only one cylinder fires at a time ,..there is no need for doubling the inboard bolts,.. making 4 bolts per cylinder or 16 bolts,unless you have individual heads for each cylinder like on some diesels..
I would use a copper ringed replacement head gasket,..and if you can not find the right torque specs ,..generally marine/auto conversion motors are torqued to motor vehicle specs plus 10 ftlbs,.. for racing motors the bolts would be replaced everytime the head was removed,..but for your application the bolts that are there will be fine ,..just check for cracks in the threads of the bolt,. if you find cracked or stripped threads ..replace the bolt,.. I would run a tap or something to clean the bolt holes in the block before installing a new bolt if I found stripped threads. DO NOT put lock tite on the head bolts,..never sieze is ok on all the bolts ..manifold included,..builders preference
Cooling problem Ford 302 san Propulsion 38 05-29-2011 11:44 PM
Ford 302 in Campion steele m.a. Sterndrives 1 04-01-2011 03:12 PM
Ford 302 Backfiring babs240sx Gas Engines 3 07-08-2010 10:13 PM
302 Ford/Mercruiser safesheet Propulsion 0 01-08-2008 01:30 PM
Mercruiser 302 Head Gasket? n0dih Gas Engines 3 08-08-2006 11:59 PM
