Old 06-22-2006, 11:24 AM
joanimal57 joanimal57 is offline
HC700 Donovan in Navy Seal Attack Boat??
Hi, I'm new to this forum. I have a dillemma concerning a Donovan HC700 big-block Chevy style engine block used in a Military attack craft. It has 750 cu. in. w/ .400" raised cam and 11.100" deck height. I purchased one of these bare aluminum blocks, used, from a Navy auction. The problem I am having is that the block is missing the main caps and has 3" mains and a center thrust bearing. It uses Oldsmoble bearings and crankshaft. Has anyone had experience with these animals? The folks at Donovan aren't inerested in talking to me about making a set of caps for a used engine block. Their suggestion was to cut it in half and throw it in the aluminum barrel. Unfortunately, it's a brand new block that they sold for $8,750.00. I am trying to find a set of main caps or the dimensions to make some replacements. The vessels themselves were built by Innovation Marine somewhere in Florida, according to Donovan. Any and all info will be appreciated. Thanks in advance, Joanimal57
Old 07-06-2006, 03:37 PM
stonebreaker stonebreaker is offline
Rep: 37 Posts: 437
Try some high performance race engine builders who advertise Donovan blocks on their websites. Automotive or marine, shouldn't matter for main caps, and anyway most of these guys build engines for cars AND boats.
http://www.sonnysracing.com/products...AR706-wNOS.htm
http://www.rehermorrison.com/superSeries/747.htm
http://www.steveschmidtracing.com/en...commander.html
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Old 07-10-2006, 11:03 AM
Rep: 494 Posts: 3,842
Any good tool and die shop should be able to make them for you. If there aren't any in your area I can put you in contact with some over in my area.
Old 04-16-2007, 06:11 PM
fastet fastet is offline
blk
Please call me about the blk 215-901-3600
U.S.Navy wooden boat plans 1900 WarrenN Wooden Boat Building and Restoration 3 12-19-2005 11:54 PM
semi-submersible fast attack craft.. wawa Boat Design 21 09-15-2004 12:16 PM
rudder that changes shape w/ angle of attack Sketch Boat Design 22 06-05-2004 01:20 AM
plywood, to seal or not willibuch3 Wooden Boat Building and Restoration 11 03-13-2004 07:57 PM
Seal and Varnish vs. Painted Boat marcos Wooden Boat Building and Restoration 9 03-11-2004 08:55 PM
