| GM 3.8 litre v6 specifications I am looking at fitting a GM 3.8 litre v6 to a 15' boat i am designing. But i need to know some important specifications . The distance of the underside of the sump to the engine mounts? From the engine mounts to the top of the engine? The overall length of the engine? From the centre line of the crankshaft, how low is it from the engine mounts? And the overall width and length. if anyone can help me with any of these questions it would be a big help.. cheers |
| hello ozpoly, why don't you go to the nearest wreckers and get your measurements off an engine, i assume you will be marinising a commodore engine, you can also buy a cheap haynes manual for the specs.
__________________ brendan . |
| Im sure it would be a great help for a job like that but these guys here are like you and me, no one will be able to answer those questions. These are the problems you come up to on a job like that. |
| its all in the OEM drawings of a Mercruiser should your engine be using the same sump and mounts Every dealer should have them or certainly get a drawing or www.gmpowertrain.com and send an email
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| WOW...Holden...You Aussies with your Road Warrior jokes...JK. OZ, The dimension are hard to find. I'm with WP23 get the measurements you need from a wrecker (can only imagine how many were made WW). That engine was converted for marine use (used in a lot of FWD cars), look for conversion parts... that should get you close to the dimensions you need on the bottom. I say this because you want a rear sump oil pan. |
| oops then try www.kmrolco.com they sell marinising gear so maybe they have dimensions ( thats an Australian built Buick for those foreigners)
| thanks for the help. kmrolco was very useful |
| so the conrods have s bends in them so they dont hit each other?
| A bloke in Melbourne put a 3.8 engine on a Mercruiser Alpha 1 drive. Had to make all his own manifolds, coupler etc but it went like a dog shot in the bum!!! Far better than the 470 it replaced. have a look at; http://forums.iboats.com/showthread....ighlight=4bait |
http://en.wikipedia.org/wiki/Buick_V6_engine |
| DC, I looked at that Wiki page and was thinking about the 3.8/3800 I have worked on and 2 I've owned, I could not remember any of them having a bank offset. I thought there may have been some confusion with the even fire and odd fire versions of this engine. |
| Even fire vs odd fire is only affected by the crankshaft geometry, not the block. The original Buick V6 was essentially 3/4 of a V8, and the V6 used a crankshaft with shared rod bearing journals, the same as a V8. The rods for opposite cylinders shared a common journal on the crankshaft which resulted in uneven firing intervals. Around 1977 GM changed the crankshaft to one with offset journals so that the firing intervals were even. The bore offset in the earlier engines was relatively small, 5 mm or so, and may not have been very noticeable. |
| 1998 Mercruiser/5.0 Litre Leaking Drive Oil | BonesNTX | Sterndrives | 1 | 03-25-2008 03:55 PM |
| Construction specifications | GoSlow | Boatbuilding | 0 | 04-11-2007 01:29 PM |
| Travelift specifications | gonzo | Boatbuilding | 3 | 12-28-2004 06:29 PM |
| 5 litre hydroplane | four04 | Powerboats | 0 | 07-07-2003 05:46 PM |
| 2.5 litre hydroplane design | Archive | Boat Design | 1 | 06-12-2001 02:44 AM |
