The only engine I know that has right bank forward is/was the Holden 253/308 as purpose built for right hand drive cars ( not imposible to build and engine without an offset but why would you you would have the rods not centered in the pistons and need offset rockers to get to the pushrods or do OHC and share big ends like a Rolls Merlin)
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
The bore offset of the early Buick V6's which has been mentioned was an offset of the cylinder centerlines relative to the crankshaft centerline such that the cylinder centerlines did not intersect the crankshaft centerline. |
next question, why did they do that? trying to fix the vibration or something?
| I know of two reasons given for offset bores. One is packaging internally within the engine. The other is so that the expansion strokes take longer than the compression strokes. The benefits of the latter are small, and on a V engine would require cylinders to be offset asymmetrically. Offsets of the magnitude generally used would have only a small to negligable effect on engine vibration. The Buick V6 geometry goes back to the Buick aluminum 215 cubic inch V8 which was introduced in the 1961 model year and designed around 1958. My guess, and only a guess, is the cylinder banks were offset outwards to provide more space in the engine "valley". |
| Y'all are confusing engines here. The Buick 3.8 v6 is COMPLETELY different from the GM 3800 (series 2). Yes they're bot v6 engines that displace 3.8 liters, and they came in Buicks, but that's it. The 3.8 is a 90 degree motor, and the 3800 is 60 degrees. The 3800 is great. Compact, powerful, light. Great motor. |
You may be confusing it with one of the other 60 degree V6 engines GM has built. |
| Ok my bad. It is a 90 degree block, but it uses the 60 degree bellhousing. That's where I got confused. Pretty much everything is different from the older ones (parts don't swap). |
| 1998 Mercruiser/5.0 Litre Leaking Drive Oil | BonesNTX | Sterndrives | 1 | 03-25-2008 03:55 PM |
| Construction specifications | GoSlow | Boatbuilding | 0 | 04-11-2007 01:29 PM |
| Travelift specifications | gonzo | Boatbuilding | 3 | 12-28-2004 06:29 PM |
| 5 litre hydroplane | four04 | Powerboats | 0 | 07-07-2003 05:46 PM |
| 2.5 litre hydroplane design | Archive | Boat Design | 1 | 06-12-2001 02:44 AM |
