| GM 3.0 4 Mercruiser OL6950501 HI looking for a schemtic of a GM Alpha one engine found a bolt missing in the Head i think looked threw shop manual cant find the exact location Any help thanks |
| If it has been running like that, you should change the head gasket. Are you sure the head of the bolt didn't shear off? The manual is very clear about the position of the bolts. Look at the picture that tells you the torque sequence.
__________________ Gonzo |
| post a photo
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
![]() ![]() The GM 181 CID head and it's gasket. Which one is missing, frankly it's fairly obvious as to where they normally live. |
| Thanks found out that it is was a holder mount for the main harness was removed and rewired . |
| mercruiser v6 overheated | mark_fitzy | Sterndrives | 2 | 04-20-2009 05:44 AM |
| MerCruiser D-Tronic ? | River Island | Sterndrives | 1 | 09-04-2008 10:52 PM |
| Crusader to Mercruiser | amerosport | Gas Engines | 4 | 04-16-2008 03:37 AM |
| Mercruiser 898 | gerhern | Propulsion | 0 | 10-31-2007 06:00 PM |
| Mercruiser exhaust | cptmclark | Propulsion | 0 | 07-31-2005 10:19 PM |
