Old 12-13-2007, 02:01 PM
adamanderr adamanderr is offline
Rep: 10 Posts: 23
ga sblock diesel heads?
Where should i look for info or possibility of converting a gas block to run on diesel? is it as simple as bolting on compatible diesel heads, since fueling and valve etc are in head? what about having a head machined?
thanks
Old 12-14-2007, 02:38 PM
Rep: 1397 Posts: 7,215
The only gas engine I know of that was converted to diesel was the Oldsmobile 350 in the 70's. However they used a hardened alloy crankshaft and larger main bearings.
Old 12-19-2007, 10:34 AM
martinf martinf is offline
Rep: 19 Posts: 51
Can't do this. Diesel's need to withstand huge internal loads as compared to gas engines. For instance, typical comp in a gas engine cylinder may be 150 ps1 and 1000 in a diesel, and, because of this, cranks, rods, pistons...it's all beefed up.
~martin
gas block with diesel heads adamanderr Diesel Engines 8 12-19-2007 01:48 AM
Such a thing as prefab heads for boats ? CgarciaDesign Materials 0 09-25-2007 03:37 PM
(sold) GM 12v or 16v Model: 149 Cylinder Heads Micom Diesel Marketplace 0 07-04-2006 12:15 AM
how far apart should my bulk heads be mattoc Boat Design 8 03-04-2006 02:38 AM
Shave engine heads finley Propulsion 11 09-28-2004 11:02 AM
