| frozen fuel pump push rod Has anyone ever come across a frozen or seized fuel pump push rod in a 454 Mercruiser? I have & I am having some dificulty breaking it loose. Does the cam have to come out to remove it, or should it drop out the fuel pump mounting hole? |
| They usually drop by their own weight. Keeping them in place to install the pump is the tricky part. Seems like it bent.
__________________ Gonzo |
| The prior owner had it converted to an electric pump that was incorrectly wired. I am trying to restore the motor to it's original condition. I think I now know why the electric pump was installed. |
| If you have an electric pump, make sure is marine and that there is an automatic shutoff switch at the oil pressure line.
| That's why I removed the electric, it was not marine, it was too week & there was no safety mechanism in place; if the key was on, the pump was pumping! The prior owner was a real brite guy. |
| Also, make sure the pump is 5-7PSI. More than that makes the carb overflow at low RPM and waste fuel.
| I want to get that push rod out & put on the mechanical pump that she was born with. |
| update Just an update, I gave up on the mechanical pump & installed a Holly marine pump. That push rod was not getting out of there. Thanks! |
| How is it running?
| Well, that's another story. I ended up having to disassemble the carb & give it a good cleaning. I rebuilt it using the original metering rods & springs. I replaced the needle, seat, accelerator pump etc. It starts right up & idles great. I launched her yesterday, it runs great up to around 2200-2400 RPMS. As I tried to accelerate her on plane; she started popping pretty bad from the carb. I'm not too familiar with the 454's, I think I set the timing correctly. There's a groove on the balancer (I assume that it's the TDC mark). I set the timing to 8 deg BTC based on that groove and the timing marks on the cover. I took her out again & I got her up on plane to around 3000 RPM's. She started poping again, but not as bad. I went back & checked everything. I did not get a chance to take her out again, but when I rev the motor quickly in neutral; I still get a pop every other time or so. I'm assuming I did something when I re-did the carb. I'm pretty frustrated right now. The transmission swap went very well though. any ideas? |
| It will pop like that if the mixture is too lean
| I'm pretty sure I have the float set incorrectly. I am also not 100% certain that the primary metering rods are correctly seated on the hanger. |
| All's well, I'm getting 12.5 knots at 2800 RPM, 15 knots at 3200. The motor was running a tad on the warm side so I didn't push her. I feel I should get close to 20 knots at wot. Not too bad. A new raw water pump impeller & I should be sailing smoothly!. ![]() |
| emergency fuel pump | kelp | Propulsion | 3 | 06-18-2009 06:01 AM |
| hand fuel pump | talbotcharles | Open Discussion: All Things Boats & Boating | 0 | 05-11-2009 09:11 AM |
| Vacuum fuel pump | Rangerspeedboat | DIY Marinizing | 5 | 04-28-2009 09:06 AM |
| '90 Alpha 1 5.0L Fuel Pump ???? | srodster | Sterndrives | 3 | 07-07-2008 09:34 PM |
| Fuel Pump or no? | seaARK03 | Powerboats | 4 | 10-26-2005 05:18 PM |
