Old 07-06-2010, 04:47 PM
babs240sx babs240sx is offline
Rep: 10 Posts: 6
Ford 302 Backfiring
I have a 1976 Hawaiian with a ford 302 in it. It starts up and runs and revs fine in neutral but when I put it in drive it will shut off or when it does work it will backfire while getting into higher rpms. Has anyone else had a similiar problem on theres?
Old 07-06-2010, 11:01 PM
Rep: 10 Posts: 6
Fixed it, it had the wrong firing order. But now when it dies it is hard to get going and sometimes have to keep cranking on and off for like thirty minutes to get going be for it will fire up
Old 07-06-2010, 11:05 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Stop stop stop right there or you will burn out the starter 30 minutes????
Getting it checked by some one that knows what they are doing will be half the price of a starter.
So many things it could be,-- impossible to diagnose on the internet with your explanations
Old 07-08-2010, 10:13 PM
Rep: 1493 Posts: 7,447
Remember that Fords have a different cylinder numbering that any other engine. Seems like the timing might have been right before.
Cooling problem Ford 302 san Propulsion 38 05-29-2011 11:44 PM
direct relacement for Ford 302? twentybelow Sterndrives 1 10-02-2009 12:33 PM
Ford 302 Engine Replacement jabroni Inboards 10 09-11-2009 09:30 AM
Smoking FORD 302 CID jabroni Gas Engines 3 05-26-2009 03:08 PM
302 Ford/Mercruiser safesheet Propulsion 0 01-08-2008 01:30 PM
