To simplify- think of your 2 engines as one, so a 458 CID V12 Being a 4 stroke,each revolution uses half the displacement of air= 229 CI of air per revolution. At 1500 rpm it would be 1500 x 229= 343,500 CI of air/min. One cu.ft of air is (12x12x12) 1728 CI -343,500/ 1728 = 199 cu. ft per minute at 1500 rpm used by both engines. At 3000 rpm- 400 cu.ft. a minute. At 4000 rpm- 533 cu ft/min At 5000 rpm- 666 cu ft/min. At any rate,that 3.98 sq ft cross section (144 x 4) would be 576 square inches or a 27" round vent. So to support 4000 rpm using his calculations. -(398/1500) x 4000 =1061 square inch intake Which would need about a 36" diameter round intake. If you were running 2 or 3 Griffons,maybe. http://www.youtube.com/watch?v=QdfO657zHNY Last edited by WestVanHan : 06-29-2010 at 07:50 PM. Reason: minor math etc |
| I dont know where the lack of knowledge comes from, every manufacturer I know will supply you air volumes and btu ratings ( heat rejection)for their engines so you can work out exactly how much air you need to keep x temperature in an engine room with x ambient.
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| engine room ventilation inlet - height above deck/ which deck | expedition | Boat Design | 5 | 06-16-2009 06:34 PM |
| Under deck ventilation? | CapeCodAngler | Wooden Boat Building and Restoration | 3 | 01-26-2009 01:28 PM |
| EFI and ventilation | curtis73 | Sterndrives | 6 | 11-09-2006 04:29 AM |
| Do boats have enough ventilation? | Elena | Marketplace | 1 | 10-21-2005 06:46 PM |
| Engine Room Ventilation | dereksireci | Boat Design | 8 | 08-13-2004 04:38 PM |
