Old 03-05-2007, 12:27 AM
majmacv majmacv is offline
Rep: 10 Posts: 2
engine swap on '04 sea ray 185 sport
Im looking for input regarding my desire to replace a 4.3L v6 with a 420 HP small block chevy in my '04 Sea Ray 185 Sport. my questions are:
1. Will it fit (I have the optional sport interior with the rear bench seat, and there seems to be alot of room)
2. what changes to the outdrive will i need to make (Alpha I) to handle the extra power (stronger bearings, different ratios, etc.)
3. Is this boat even safe to operate at 65+ MPH? (i.e. is the overal hull design desiged for these speeds)
can i modify the transom to accomodate thru-hull exhaust?
Any input is greatly appreciated!
Andrew
Old 03-08-2007, 08:12 PM
mtnrat mtnrat is offline
Rep: 10 Posts: 53
I would post this under the sterndrive section, you may get a few opinions there.
I am always one for more power But,
1. dont know
2. don't know
3. That is a pile of power for that boat. I would think things may get a little squirrelly at those speeds.
Old 03-11-2007, 08:53 AM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
Your 4.3 is nothing more than 3/4 of a chevy Sm Blk. The V8 will be approx 4 1/2" longer, same width with stock exhaust manifolds.
In order to get that kind of power from a small block,a High output Cam is required which results in max HP developed at Higher RPM, probably 6000 +. If the WOT engine speed is 6000+ , gear ratio need not be changed. Probably OK as is, however longevity will probably be less depending on how much the Boat is run wide open.
Depending on water conditions, 65 MPH shouldn,t be a problem
Old 03-11-2007, 06:07 PM
Zackman Zackman is offline
Rep: 10 Posts: 19
Andrew, I believe the 4.3 was the largest engine offered in that boat. With the alpha drive you are limited to 300 Hp. The drive is limited in speed also, I believe 60 - 65 mph. With that drive, the 350 Mag (300 Hp) would be the biggest you could connect to the Alpha. I would save your money, and get the boat you really want and sell that SR to someone it would better suit.
Old 03-16-2007, 04:10 PM
Rep: 10 Posts: 2
Thanks for the info!
Andrew
Old 03-24-2007, 10:03 PM
RMSOSF RMSOSF is offline
Rep: 10 Posts: 55
420 HP small block???? alot of power for a mouse.
2006 SeaRay 185 sport new2boating Powerboats 7 10-25-2007 01:35 AM
3.0 i/o locked up--sea ray sea pit Inboards 3 08-16-2006 07:03 PM
Sea Ray 185 Or Regal 1800 Help? ACHALAT Powerboats 4 11-20-2004 10:54 PM
Re Flooring My Sea Ray Dennis Curtis Boat Design 2 03-12-2004 10:19 AM
What do you think of the New Sea Ray 680? Archive Powerboats 7 06-12-2001 04:42 AM
