Old 06-08-2012, 11:19 AM
sgfisk sgfisk is offline
Engine rotaion
I am rebuilding a small block Ford in a 1995 Four Winns. What is the correct firing order. Is it a reverse rotation engine?
Old 06-08-2012, 03:14 PM
IMP-ish IMP-ish is offline
powerboater
Rep: 136 Posts: 349
Post the engine model.
Old 06-08-2012, 10:05 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Rep: 574 Posts: 1,036
Easy:
-turn the starter over,note which way the engine turns when viewed from the front.
-find the displacement,and look up on google.
-and/or contact customer service and ask them
Old 06-09-2012, 01:54 PM
powerabout powerabout is offline
Rep: 621 Posts: 1,744
if its a stern drive then all same like a car, clockwise from the front but that is called Left hand in the marine world as they look at the flywheel.
Never seen a reverse rotation ford though?
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 06-15-2012, 03:36 PM
7228sedan 7228sedan is offline
Rep: 51 Posts: 108
most likely 1-3-7-2-6-5-4-8 as I believe the marine engines all had the H.O 302 (same as 351) firing order. If not try 1-5-4-2-6-3-7-8.
MORSE ENGINE CONTROLS for Twin-Engine Inboard FOR SALE scottsgretch Marketplace 0 01-25-2010 08:30 PM
MORSE ENGINE CONTROLS for Inboard Twin-Engine scottsgretch Marketplace 0 01-25-2010 08:15 PM
Vetus electronic engine remote controll, and setting starbord engine do conter clockw omnitrips.com OnBoard Electronics & Controls 11 06-21-2009 02:43 AM
From a V-? engine to a 4 cyl.... building the front engine pad sikpupy Fiberglass and Composite Boat Building 0 06-10-2008 09:39 PM
140 mercruser engine c.i.d. identificafion by engine serial number ggsimpson Gas Engines 0 11-18-2006 11:39 AM
