Old 08-09-2006, 10:23 AM
shelbygone shelbygone is offline
Rep: 10 Posts: 10
cracked block
anybody out there have any suggestions on fixing a cracked engine block? glue,epoxy,prayer? i had a guy from a welding shop look at it and he said it would probably spider crack so i guess thats out. i'm not very happy. thanks guys.(and girls).
Old 08-16-2006, 05:09 AM
Rep: 1397 Posts: 7,215
It can be welded. Find a welder that is familiar with engine block alloys. However, it may be expensive.
Old 08-16-2006, 07:32 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Welding blocks aint easy, it depends on where the crack is, it may need the block in a furnace to heat up the whole block , this of course is a major strip down and some would say needing line boring after. You might as well stop right there and buy a short motor.
OR again depending on where the crack is there is a technic called cold stitching. this is basically drill a hole right at the end of the crack ( not easy to determine) and thread it and put in a plug. You then drill through half the the plug and crack thread and plug again, repeat till crack filled .
I beleive you can buy a kit to do it yourself. Someone had a thread on this not so long since.
I had a piece of block the size of your hand come out of a Chevy 350 due to freezing damage. I cold stitched it,-- cost a fortune, lesson learned should'v bought a short motor. Oh well
Old 10-11-2006, 08:57 PM
grumpygrady's Avatar
grumpygrady grumpygrady is offline
landlubber
Rep: 15 Posts: 18
if the crack is in a water jacket area you can use waterglass in the cooling system to stop it up this is what they use on the on the road trucks and equipment when they crack a block from cold or flex
Fix this block brokensearay Sterndrives 5 12-13-2006 10:16 AM
Fairing block for helm chair CaptHank Boatbuilding 5 04-12-2006 05:53 PM
new capt on the block drbrooks Wooden Boat Building and Restoration 2 03-09-2006 07:12 PM
Volvo block number PJC Propulsion 1 12-03-2005 07:03 PM
causes of engine block cracking? lapaz Propulsion 3 08-15-2005 07:57 PM
