Old 07-08-2010, 03:20 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Originally Posted by Redtick View Post
One rod per crankshaft rod journal.
All the rods should be the same bore and length. Using the same bearings, I would not do, but look on the back side of the bearings for any stampings that may show an oversize bearing. Mic the journals for undersize, uniform size and being round. Use plastigauge to check clearances, even after using a mic.
http://www.plastigaugeusa.com/how.html
Hone the cylinders and use new rings and bearings, it will save you money in the long run.
If in doubt, it's always cheaper in the long run to have a machine shop or engine rebuilder do the work.
Take it to a engine place and get the bores honed , new bearing and let them fit the rings to the pistons and the pistons to the bore with new bearings to the short block stage !! . the number on the rod goes to the camshaft and there should be a triangle stamped on the piston that indicated the front so look for that and it will tell you which end is one !!
Old 03-13-2011, 03:04 PM
spain spain is offline
all modells of chrysler mariner sale.
Hi I have a manual of all chrysler models if you need any send me a message with the model in question and see if I have it and the price certainly comes cheaper than anyone.
Chrysler 440 fuel pump Marine vs Auto? mlcorry Gas Engines 6 01-06-2010 11:46 AM
Engine Swap Chrysler 318 to ???? sportfishermans Inboards 6 11-14-2007 05:31 PM
The Dreaded cockpit sole Dilema!!! grady Fiberglass and Composite Boat Building 11 11-27-2006 08:46 AM
Chrysler Marine Engines whoz yer daddy Propulsion 0 10-10-2005 10:17 AM
propeller dilema schwing Boat Design 11 02-17-2004 06:10 PM
